ROUTE MONITOR - NAVIGATION
The car park is seriously up hill from home. It is certainly taking topography into account when route planning.
Last summer when I drove up the Furka Pass in Switzerland, the Porsche planner showed how much I would lose. I can't remember the exact numbers, but let's say it showed I would be left with a 50% range from the 70% I started with.
And on the way back when I changed the navigation back to where I started (all downhill), the navigation showed I would be back to 70%.
And that was the case. A pleasant surprise.
GasStation
GasStation
Montreal, Canada
Macan Turbo EV
I suspect you are being unduly pessimistic of the route planners capability.
When I plot a route to a car park I walk from regularly it says it will take 6% charge to drive the 11 miles to get there. When I plot a route from that car park back home the planner says it will take 1% to get there. The car park is seriously up hill from home. It is certainly taking topography into account when route planning.
It may "remember" past consumption or specific to and / route consumption too.
It certainly appears to retain "past" information that negatively affects the range output as we poor saps are having to manually reset the BMS through the up and down re-calibrations that are being discussed at great lengths in these Forums.
Terrain Database...hein, I doubt it. It's simply a calculator doing the math. Don't get me wrong, I don't think any EV out there right now has a true topographical database as part of it's route planner.
However, back to my pics and initial query with the "route calculator", if you tell me why my route planner is telling me that I will arrive with more "juice" than I currently have in my high-voltage battery without any planned charge session, I will gladly bid an LHR turn and buy you a pint or two. 😉
Electric Macan EV ROUTE MONITOR - NAVIGATION IMG_1756
Electric Macan EV ROUTE MONITOR - NAVIGATION IMG_1755
ChrisFromUK
To me, everything suggests that it does take terrain into account for route planning.
As to the higher SoC on arrival - I agree this is nuts crazy. Mine did this too for the first time last August and it lasted for two weeks before reverting to normal operation. It's come back a couple of times since for short periods but I don't think I've seen it since the big 28.13 software update.
It's possible that it went away on mine after a run down to a lowish charge then a charge up to 100% or thereabouts. Definitely worth a try. Others report changing to the guest profile resolves it. To me this is nothing more than a software bug that need raising with Porsche in the hope of an eventual fix maybe one day possibly perhaps.
GasStation
GasStation
Montreal, Canada
Macan Turbo EV
I suspect you are right on the software bug. The frustration comes from being BETA testers while paying so much money.
It's my fault for being overly enthusiastic in ordering and purchasing a launch luxury vehicle.
Three weeks ago, I purchased a 2026 Toyota RAV4 PHEV XSE sixth generation and I don't expect any issues with this proven product. I get 80km of EV range with a 1000 km range. I needed a break from this Porsche POS.
Thanks for you input and I will be doing another "yoyo" battery reset; it's at 100% now.
Don't overthink it, it's just another issue related to the soft and/or the bms and/or the battery and/or whatever causes that...on specific cars.
Mine is often (very) pessimistic , have a look, 12% for 60 meters :
Electric Macan EV ROUTE MONITOR - NAVIGATION IMG_0644
GasStation
GasStation
Montreal, Canada
Macan Turbo EV
I tried the Guest account and the route planner is accurate.
I am going to do a factory reset as I am unable to delete the main user account. I suspect my Porsche ID account file is corrupt.
GasStation
GasStation
Montreal, Canada
Macan Turbo EV
Factory reset completed, although it took well over 30 minutes to finish loading. I re-created my Porsche ID and the route planner inaccurate battery remaining issues reported earlier appear to have been resolved; food for thought.
Bennie
Ben
Eindhoven, The Netherlands
Macan 4, MINI Cooper S
My dealer performed the SQ5 software update yesterday, assuming it would also resolve the discrepancy between the range shown in the navigation system and the one on the onboard display. It turns out that wasn't the case.
They now want to charge the battery from completely empty to fully charged and investigate the matter further. I’ve asked them to first seek more information from the importer Pon / Porsche on how to fix this issue.
Does anyone here have any insight into how to resolve this difference in range between the navigation system and the PCM?
Is a factory reset the only solution?
atebit
PA
Macan 4, Macan 4S
My rule of thumb: at any point in your journey, if the dashboard SoC is <= 30 miles more than the distance to the destination, start looking for a charger. Of course, if it’s tending that way much earlier, plan accordingly sooner.
I had that exact issue. They had the car for 5 days. (I had a curtesy car). Before they consulted HQ and initially charged it to 100% and put some miles on it (asked if that would be ok). Then installed 6 small updates one of which was battery management. All sorted.
Bennie
Ben
Thanks Bob,
So, it turns out it can be fixed with a software update after all—just a different one from the SQ5 update they installed on Tuesday.
Do you have any idea what the version number was for the update that fixed the issue, or is that something you could find out by contacting your garage?
My dealer certainly doesn't have this information; otherwise, they would have installed it.
Thanks in advance!
Bennie - I’ll try and find them out as I don’t think the car can confirm them.
ProcessEng
A
Jacksonville
2024 Macan 4 EV
Recently had software update done at dealership and now experiencing the same issue.
previously the route planning and destination charge were incredibly accurate and took into account many things listed by others. As far as topography, my Macan definitely used to take this into account. Driving in the north Georgia hills it would estimate that I would reach the bottom of the road with more charge than I started with and my consumption would go to single digits and the percent charge would increase.
Other than weather affecting the traffic or speed of travel and then the route planner adjusting; I have never seen it consider weather conditions.
not sure what the update was addressing but it definitely bricked the navigation charge estimation. Will try the 100% charge tonight
Had the same problem a couple weeks ago. Performed a full charge and now it works perfectly again (no SQ4 and/or SQ5 software update yet)
