Range / consumption of 2025 Macan EV ?
SCOUBI22222
ARNAUD
FRANCE
PORSCHE TAYCAN ST
Good morning,
I still haven't fully understood the consumption of the macan ev, what real range can we count on with its 95KW battery?
SCOUBI22222
ARNAUD
FRANCE
PORSCHE TAYCAN ST
Like my rear-wheel drive Taycan.
On videos in France, it was around 23.3 on the highway, or 400km.
Was even higher on the highway but on backroads with sporty driving 19kwh/100km? The issue with that part of France is that there can be a lot of wind …
Anyway that is why I have opted for the 20 inch wheels should add around 10% range/lower consumption.
Wired’s review: https://www.wired.com/review/review-porsche-macan-electric-2024/
WIRED said:
WIREDdrove both models but spent more time with the Turbo, in which our average energy consumption hovered around 3.5 miles/kWh, giving a theoretical maximum range of about 330 miles.
My best guesstimate is that with our Turbo, with its 22” aeroblade wheels, we would be averaging about 305 miles (if/when we rarely need to charge to 100%), of course reduced to around 250 at freezing; 225 miles at 15 F and up to 340 miles @ 85 degrees F. We are fine with these numbers and will adjust these SWAGs as actual range tests from those I am most looking forward come in: Kyle/OutOfSpec; Thomas/Autogefühl; Tom CLoughney/StateOfCharge; Brian Wong/Edmunds; and from Bjorn Nyland, we will then all see what are test based results.
Interesting to see the EPA results — which we now understand are not coming until sometime this summer.
Lastly, I fully agree with those who are planning to get 20” wheels, that you will be getting roughy 10% more range. But as we charge in our garage when needed, and on our so far limited road trips, we have yet to need to add in one more charging stop and so we are fine with the 22“ wheel lower range. We have a BMW iX M60 with 22” wheels; it weights 400 pounds more; and, it has a slightly higher CD — and two weeks ago on an average 57 degree F day we got 350 miles on it.
As our daughter who now has her second all EV said to us before we got our first, the first three months you will stress, constantly checking your projected range left, but after a while other than trips, you will just drive it relaxed. She was right.
Daniel
Europe
Sold:Taycan 4, Now Macan 4, on order Macan GTS
I usually choose 20 '' wheels (lower consumption and winter tyre mount) but the Macan 4 ones are so ugly (in my opinion ...) that i opted for the 21''
SCOUBI22222
ARNAUD
FRANCE
PORSCHE TAYCAN ST
Also I chose 21p, on the different videos have sometimes seen on the main screen sometimes 440km sometimes 550km,
It's quite disturbing this difference when they were in the same place for the test
If one drives it like a Porsche as some reviewers have done, those are most probably the ones with the 440 km numbers.
Reality (UK) is looking like 270 miles (min) which isn't spectacular IMHO but unsurprising given our climate 9 months of the year. Easier driving and decent ambient may see 300+. Folks in US - SOCAL, Florida will see much more (they already do with their existing Taycans).
ironcitijc
JC
NH
Macan 4S, Rivian R1T
I’m in the same boat. Still going back and forth with my final configuration but as much as I’d like the increased range with the 20 inch wheels I’m most likely going to end up with a 21s just based on appearance ?‍♂
Same here, was going to go with the Turbo wheels (more tempted for 21” over 20” but unsure)… and then all the recent pictures of the Turbo rims showed me the way.
Macan Design in 21”.
Jetced
Cedric
Bratislava
Macan EV turbo 09/24
yeah, also went for 21'' on the turbo. Where I live the streets are incredibly bad, I'd be happy with the extra rubber
nulled
Btw the config calculates the range based on wheels and roof rails. You need to click on "technical data"
That's true for countries in Europe because they use WLTP - and a good indication for all.
That's sadly not available yet in the US (the EPA numbers still not available).
A generally good conversation factor is to divide WLTP amount by 1.12 — to get close to EPA figures. That ratio has worked pretty well for most EV’s. We shall see how it works around this summer when we get EPA actuals for the two Macans.
