Extremely Slow Charging Speed at EA
Paris92
SFO
2025 Porsche Macan 4 EV
Have brought my 4 to EA high-speed (350kW chargers) Flagship location in San Francisco the last two days as part of my free charging period. Both days I have used the Porsche trip planner to navigate to the EA location. Both days I am experiencing extremely slow charging speeds (under 30kW.) Yesterday I only drove here in under five miles so I thought maybe the battery didn’t precondition, and EA was full; every bay taken. Today I had been driving around for over 25 miles and again used to trip planner to navigate to EA figuring the battery would precondition under that circumstance. Again getting under 30 charge speed. Thinking it’s a “my car” issue. EA bays are less than 50% occupied today.
it could be sooo many things - you need to check other EA sites under difference circumstances
battery temp
SOC is critical information…
did you move stalls?
Paris92
Paris92
SFO
battery temp
Moved once, yes. Battery temp was in the 70’s when I arrived. Charged from 45% to 63% in the 30-minutes free period. Charging speed as low as 22kW and as high as 39kW. Seemed very slow to me for starting at 45%. Maybe I’m wrong but it’s never trickle charged like that at EA for me in the past.
FirstEV
Sweden
This is obviously very low. I’ve charged my car at -1°C (30°F) and still managed to pull at least 60-100kW on a 360kW charger until the battery reached higher temperatures. SoC was between 15–30%. That said, I would tend to agree with the comment above. It is probably worth first checking whether this is related to the charging facility itself.
BUT, I would like to add the caveat that I’ve seen many charging issues with NA cars, so it might not be entirely fair for me to compare it with a European one.
Paris92
Paris92
SFO
Thanks. I have been to this particular location many times over the last nine months with very high-speed charging. Yesterday and today are the only times I have had this slow rate of charge at this location regardless of my starting SOC%. I am going to search out another location this week and try that.
Try a different EA to eliminate the charger, but agree regardless of low Battery Temp and high SoC, the speed is way too low.
Otherwise:
- Battery Temp is too low to accept max speed
- Monitor Battery Temp to make sure it is heating up to 90F+ (pre-conditioning)
- SoC is too high, try to be at 15% or below
SandyHaus
Sandy
Denver, Colorado
2025 Macan 4 Electric
Couple of other things to try. . .
Try going to your local EA In the middle of the night when no other cars are charging and see if that helps. Also try calling the EA phone number on the charger while connected and see if they can trouble shoot.
Sandy
Try non-EA as well to rule out something like cell imbalance/recalibration required on your car.
I've charged at that location before (if it's the Harrison 20-charger flagship location) and it charged a lot faster. It does seem like it's either something wrong with your car (try a different brand in a different location?) or EA is having some real constraints. If you glance at the charging rate display of the other vehicles, what are they at?
Paris92
Paris92
SFO
Yes, that is the same location I charge at. Typically has been much much faster there for me.
ron_b
Ron
California Central Coast, USA
2026 Macan 4 (waiting at dock), 2020 Taycan 4S
Can you share a photo of the left “tube” when you are charging? It shows the battery temperature and such.
