A negative # isn't a "negative tire pressure" reading but rather indicates the amount of change since the last reading (e.g. it thinks you've lost 3 PSI).My latest problem is every time I get in, and multiple times while I'm driving, it tells me I have negative tire pressure (-3). The fix is just to toggle tire sizes.
<snip>
And this icon overlay glitch was not fixed yet with an update?Apart from one glitch in PCM where the icons overlay… I’ve not experienced any other issue with my car. I had quite an extensive build with several technology options (Drive Assist, keyless, HUD, Remote 3D park etc). It’s two months old, just tipped over 2k miles.
Not that I’ve experienced and it seems like it’s been an issue since the first MY26 cars landed.And this icon overlay glitch was not fixed yet with an update?
Interesting. I've had fluxuations before and it just shows the actual number and says it's lower. Now it no longer shows me the numbers just "--" and throws up negative numbers somtetimes.A negative # isn't a "negative tire pressure" reading but rather indicates the amount of change since the last reading (e.g. it thinks you've lost 3 PSI).
I assumed that the negative or positive deviations were in relation to the variability to target pressures.Interesting. I've had fluxuations before and it just shows the actual number and says it's lower. Now it no longer shows me the numbers just "--" and throws up negative numbers somtetimes.
