Electric Range
if you drive off with no heating / aircon on and after say a mile then put on the max heat / screen on - watch the range dive by up to 50 miles. In the relatively mild winters in the UK I think the heating on has a bigger effect than the the external temp on the battery
Max Heat uses resistive heating instead of the heat pump so you should avoid using that if range is an important consideration for the trip.
Instead set the desired cabin temperature and turn the AC to ON in AUTO mode, with the seated heats and steering wheel heating on for a few minutes until you're comfortable, then turn them off.
aks
Tony
Hertfordshire, UK
BMW F90 M5, Macan 4S
Presumably, pre-heating whilst the vehicle is still plugged in costs zero miles?
Throb
NL & UK
In my Macan Turbo I get a real-world range of around 330km (205 miles) in winter, and maybe around 370km (230 miles) in summer. This is at a cruise of 120km/h (74 mph) on the motorway.
I have 22" RS Spyder rims.
Reactions: MMR
grahamlind
Graham
Worthing
Macan 4 Electric
Thanks everyone for the advice and feedback, temperature here has been around 40 degrees (F) so it looks like the range is what I can expect in those kind of temepratures.
Fluff
if plugged in, it should extend your range, lets say you will use 2kwh to heat the cabin from cold - this now comes from the charger, so you effectively gain 2kwh of range - 4-5 miles.
Reactions: aks
Fluff
it does dive, but its assuming you will run this level of heat until you hit zero battery. In fact normally you will turn off heated steering wheel, turn down heated seats, and heater, as the cabin warms up, and your range will slowly improve.
Reactions: aks
On the official website is says “Electrical consumption combined (model range): 3.5 – 3.0 mi/kWh, Range combined (model range): 328 – 379 miles”
I am getting typically 230 miles to a full charge, granted it’s winter, but it’s a way off the expected range. I know the “expected” consumption is never the real consumption, but it’s quite a lot less.
What is the general experience from other Macan 4 owners on range?
As we've said a zillion times before these are WLTP (lab based) figures - in otherwords la la land.
Take 30% off or thereabouts and you'll be closer to reality.
Winter doesn't help, remember this is still old battery tech.
pdealessandrini1930
Paolo
Montauk, NY
Hi. As others have said it’s winter.
My experience for 20k miles Macan 4 with 21” all season tires on mixed motorway (65-70mph on 120mi weekend commute ) and 50mi heavy traffic weekday commute on city roads, night time with lots of electronic options plus heat using battery, 2nd winter and one summer:
spring summer fall: up to 390mi and a few times 405(!?!?) miles
winter: reads 303-309mi on app and in car screen. Leave heated garage in 0C / 32F and drops to 285-290mi instantly.
Uses more % battery for same 50mi R/T commute. 8%-10% summer vs 12%+ for same journey noting 100miles less range to begin with. No big issue. Just recharge more often and Plan travel.
de0xyrib0se
Sofia, Bulgaria
Stopped paying attention to ranges a long time ago. Is it hot or is it cold and how cold is it, is it pre-warming is it not, uphill or downhill, recoupe or not, summer or winter tires, am I going 110 or 160km/h....
Pedal to the metal! If you need to charge then charge and move on :) Heck, with the Porsche charging lounges I find excuses just to charge!
hans_
Hans
Delft
Tesla Model 3
Fully agree, in The Netherlands and the rest of continental Europe there are so many fastchargers that range is no concern at all. So what if you have to charge for 5-10 minutes.
Russ
Russ
West Grove, PA
Macan 4S EV
I'm seeing that same range, but it's freaking cold and the battery is getting sapped to warm up to operating temperature...
Try that in Scotland and see how smug you can be!
