EV Newbie planning first reasonable distance trip (UK)
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
Hi
I’ve had my 4S for a few weeks now and we are planning our first trip of any distance, which will involve a public recharge or maybe two. This is our first EV so we are public recharging virgins, and wanted to see what advice is out there on the most optimal way of planning and executing the trip.
We have…
- Porsche charge card
- Octopus Electroverse charge card
Both offer discounts but at different EV charging providers.
My preferred Sat Nav is Apple Maps as it includes UK speed cameras … but doesnt apear to natively plan a trip based on EV considerations as far as I can tell.
It seems I have a few options and am unsure of the best one…
  1. let Apple Maps guide me, and separately research fastest/cheapest charging points en route (probably Electroverse as these seem more prevalent than Porsche preferred ones around the route I will be taking)
  2. use the My Porsche app to plan the route and send the route to the car then rely on built-in navigation (but no speed camera warnings)
  3. Use the Octopus Electroverse app to plan route then send it to car, where it seems to interact with Apple Maps … but I haven't tested that one yet
  4. Others?
What are others’ experiences of similar decisions?
Also, this is a day trip to a place a few hundred miles from my home. There is no charging point at the remote destination but I do have a home charge point. Would you:
  1. plan each leg of the journey individually, and just make sure there is adequate charge (25%?) minimum at the remote location?
  2. plan the entire round trip (home to home with a stop-off point at the destination and ask the chosen app to start with 80% and be happy to end with 20%?)
As you can tell, I’m a newbie! At the risk of missing out on some of the fun of trial and error… what is the seasoned EV owners’ advice in these circumstances?
Apologies if these combos have been discussed in other threads too. Please feel free to direct me there if so…
Thanks in advance…
Tacoman
Miami
Macan S, M3
I am about to be an EV virgin come April.....so.. marked.
Throb
NL & UK
Hi
We have…
  4. Others?
Thanks in advance…
Hi
What is your actual origin and destination (roughly)? Manchester to? Might be useful to demonstrate what *my* strategy would be on your road trip.
First of all, I think you'll quickly learn how to strategise charging on long journeys as soon as you've done it once or twice. It's actually very easy. You'll also be happier going down to a lower percentage before you charge (circa. 5%, sometimes).
Some key points:
* Always aim to charge at a low percentage (less than 20%, ideally).
* Preheating is essential to get a fast charge. The Macan should do this automatically (there is no way to start it manually).
* You'll know your battery is at the optimum temperature by viewing the display in the left-hand tube in the instrument cluster. The line indicating the temperature of the battery should be at the bottom of the white "bracket".
* Aim for ultra-rapid chargers (above 250 kW, if you can). I always try to use Ionity, as they're the cheapest using the Porsche Charging Service.
* As you approach the chargers, try to find a stall that is far away from other people, otherwise you can sometimes end up sharing the power, and both of you get a slower charge.
In terms of strategy, this is much simpler than it seems:
* Forget the one suggested by the car. Often what it thinks is a good plan is far from it.
* Navigate each leg separately. You know roughly how far you'll get on your first leg before you need to charge, so just think about chargers in that area. Things constantly change so it would be very difficult to plan the whole return trip without something affecting it. Be flexible.
* If there are several companies with multiple chargers in that area, you can risk going down to a lower state of charge. Alternatively, if you're planning to stop at a charger which is on its own, then allow more spare charge when you get there in case it doesn't work.
* While you're charging at the first stop, you can then plan your next stop based on how the first leg went. Maybe you got unexpected extra range?
* Always have a plan B or C, due to road closures and unexpected diversions.
* Mentally assess how your plan is going as you're driving. How's the consumption? Is there a trend with your battery's state of charge on arrival? Is the arrival percentage going up or down? If it's going down then keep an eye on whether you need to charge earlier. If it's going up, maybe you could stretch the leg out further and carry on to a different charger?
* Based on your next stop, unplug at the appropriate time.
This is a rough outline, but any questions, do ask...
Well in summer I just use Apple Maps (you can select add stop and filter on EV stations, works brilliantly), de battery conditioning is not needed.
In winter I would use the Porsche Navigation as you cannot pre condition the battery manually. (The iX can so I use Apple Maps all year long)
Some prefer to navigate leg by leg, I just put in the destination and start driving … if I see I will arrive at a charger over 20% I keep on driving and it will pick the next available one … Yeah I know this feels awkward and maybe it is in the UK, but here over in EU there are plenty of charging opportunities.
So basically I drive my EV’s like an ICE car, it takes a leap of Faith, but it works.
If you are afraid of this way just familiarize yourself with the charging infrastructure upfront …
thealbs
thealbs
Manchester, UK
Hi
Some key points:
Thanks @Throb - great advice. I’m travelling from Manchester to southern Cotswolds so will be taking in motorways initially then plenty of A + B-roads and smaller towns closer to destination. IUt seems Ionity is an option but slightly off route so wil see how I go… cheers.
thealbs
thealbs
Manchester, UK
Thanks @Yves . I didnt realise I could add an EV stop on Apple Maps. That gives me even more options ;-)
Yes when in my iX it knows apparently it’s an EV and it will show me POI that are EV on route, on second thought need to check this in the Macan to be sure …
Yes it does show the charging option when you are navigating to your destination and want to add a stop
ukdriver
UKDriver
Interesting question - Also in the UK here and also an EV virgin.
Currently I am using the inbuilt nav system because of charging concerns. Additionally I also run Waze in the background for cameras, traffic and police notifications.
You have to remember to turn off one of the voices otherwise you’d get two announcements all the time :)
That’s been my poor solution to the problem you state above.
Will be great to hear from more experienced members.
Throb
NL & UK
Right, so this is how *I* would approach a trip like this.
* Manchester to Cirencester (for example) is 148 miles, so you could make it there on a full charge, no problem, even in freezing temperatures.
* I would ask myself, "will I be able to charge at my destination, and if so, will it be to 100%? If it's a "yes" and "yes", then the strategy is simple. Leave with 100% - charge to 100% at destination - drive home without stopping to charge.
* If the answer is "no charging at destination", I would then be looking at where my last charge would be before getting home in Manchester. In this case Ionity West Bromwich (81 miles from Manchester), or Ionity Stafford (57 miles from Manchester) would be by choices.
* As you've got your plan for the last leg, you've only go to think about the middle part (i.e. somewhere in that window before arriving at your destination or just after leaving your destination.
* If you charge before arriving at your destination, then you just need to put in enough energy to get you to Ionity West Brom or Ionity Stafford (via your destination). If you charge after you leave your desination in the Cotswolds, then it needs to be fairly soon, but not too soon that your battery hasn't had enough time to pre-condition.
* There are no Ionity sites near your destination, but there is a Porsche Centre at Tewkesbury, just off the M5. That would be my first choice to stop as you get the preferred rate of 39p/kWh. The only issue with Porsche Centres are that the chargers are often blocked or not working. Therefore I may have a plan B to use the Gridserve at Strensham Services on the M5 Southbound just before Tewkesbury (59p/kWh), or the Opsrey 150 kW chargers (59p/kWh) just off the A417 near Gloucester. The reason the Opsrey is a good choice is because there are 12 chargers at that site, and even though it's 150 kW, that doesn't really affect your charging time as much as you'd think, especially when doing a deep charge. I would base how much I charge to depending on what I have to do at my destination. If you find it's taking too long, then you can adjust your final stop to Ionity West Brom rather than Stafford, and therefore you don't need to charge as long.
thealbs
thealbs
Manchester, UK
Wow - THANK YOU ! I had spotted the Ionity chargers you mentio , and they’d also come up on the Porsche route planning too for a 10-minute splash & dash (or whatever ther EV equiv of that is), so will follow your advice and schedule a stop depending on battery condition when passing throuhg.
Thanks again - really helpful advice.
thealbs
thealbs
Manchester, UK
Post-trip update….
Thanks again to @Throb and @Yves for advice.
We …
-followed @Yves advice on plotting the route with Apple Maps but including the (most likely candidate) charging points as stopovers. We made in-flight decisions on wehther to stop or carry-on, as they were literally on the route anyway.
- followed @Throb advice on sticking with Ionity and only plotting one leg of the journey at a time. Due to lower than ideal range (maybe temperature induced), coupled with a little bit of newbie range anxiety, we stopped at Ionity Wolverhampton on both legs. On the outbound leg we topped-up with 30kwh and on the return leg we took 48kwh on-board … with the second charge being 5 minutes faster than the first one for some unknown reason (despite the 6 bays all being occupied). We arrived home with 30% available, which made it all very relaxed and were charged circa £30 by Ionity via Porsche for the charges. It cost us more in coffee and snacks at the adjacent Starbucks than the energy. Note to self ... take iPad, drinks and snacks on next long trip.
Plus & Charge worked like a dream, with no need for payment cards or any peripheral items.
If we did this again, we would probably:
- research the precise location of the Ionity bays before departing (Apple Maps sent us into an adjacent industrial estate for some reason)
- check ahead on how busy the Ionity bays were. We had a 10-minute wait for a bay to become available on the return leg … and also didn't really have a Plan B in place.
- maybe plan to use Stafford Ionity in addition to Wolverhampton, so I became familiar with multiple stations on the main North West to South route in the UK.
We don’t regret taking on board more power than we absolutely required. On the return journey the opposite carriageway on the M6 motorway was blocked for circa 10 miles due to a vehicle fire and we commented on how stressed we might feel if we had been sat in that for 2+ hours without moving and stressing about running low !
Thanks again for the advice and hopefully my public charging virgin comments help others such as @Tacoman who are moving over in future…
NeilJ
Neil
Warwickshire
Macan 4S (Taycan Turbo CT and Taycan 4S sold), Cupra Born V2
Hi
Some key points:
Great advice - very much fits with the experience I’ve had with a Taycan over the last 4+ years.
You probably charged faster on the return because the battery was heated because of the previous charge … Using Apple Maps you would not have had battery pre conditioning. What you could do next time is use Apple Maps … and ones you are like 30 minutes out of your next charger, switch over to PCM navigation … That is something I do not need to do in the iX as it somehow can trigger the manual pre conditioning of the BMW …
So did you check battery temp, if you have configured that on the left dial you exactly know where you are on heating and if you can charge fast …
Throb
NL & UK
Post-trip update….
Glad you had a successful trip. It'll get even easier as you travel more. I do a lot of long distance driving, and I even have my favourite unit at certain charge stops. You'll build up knowledge of where to charge and you won't even need to plan that much. You'll also get to know your car and how far you can push the range. You'll know whether it's better to maintain a higher speed and make an extra stop, or slow down a bit and miss a stop out due to lower consumption.
