Wondering about the GTS Suspension.
twporscheguy
San Francisco
Tesla Owner
Went to test drive a turbo today since the dealer is right across from where I work. I realize that the normal mode was relatively comfortable. Sport mode was pretty acceptable compared to my current car (model s plaid; almost always in comfort). Sport plus was another beast, much stiffer and responsive.
How does the GTS Suspension compare? Would normal still feel the same and sport/+ custom dialed for GTS. Im hoping normal doesnt feel like sport mode in a GTS.
Insights please.
aks
Tony
Hertfordshire, UK
BMW F90 M5, BMW F48 X1
I tested a GTS and found the 'normal' a good bit firmer, which meant feeling bumps/potholes on UK roads - a much less desirable drive for casual driving. On the other hand, the 4 and 4S I drove, felt "much" nicer on the exact same roads, and I knew instantly which one would suit us most of the time - our 4S is due early June!
22" rims I bet which is the likely problem as pretty much all UK cars since Feb have had these fitted.
The standard rim size will be the sweet spot and the reviews I've read have been complimentary.
Overall the GTS has a sports tuned air suspension set up.
On the Taycan I went from a 4S to a GTS on 21" and the ride was just sublime.
aks
Tony
Hertfordshire, UK
22" rims I bet
Yes indeed, however all three cars had 22" rims, so I conclude the GTS does have a stiffer suspension setup - even though the reviews cover the ride in glory - it just was not my experience.
twporscheguy
twporscheguy
San Francisco
Tesla Owner
Did all three use the same tires?
That should be expected - it's a GTS - typically part of the DNA along with 10mm lower ride height regardless of Porsche model chosen. The air suspension is described as having a Sports tune in the configurator so clearly different to regular air setup on other variants and therefore no surprise or revelation.
This rarely translates to a poor ride per se but that in part will be dependent on what you are used to or expectations in mind.
22" rims would be my last choice particularly for UK roads. Some dealers have new base Macan EVs with no air and 22" - ugh!
Try one with the standard setup and you might be surprised or a 4S with air and 22" rims abd be disappointed.
There's a combination there for everyone.
Reactions: aks
PastaSource
Mario
Surrey, UK
+1, and why I'm ending up just going with standard (21's) on the GTS order. I was happy with this from a looks perspective once I'd seen the 21's IRL too.
Having driven 4/4S and GTS on 22's the GTS definitely felt a little firmer on normal, even if that difference was minor it was noticeable to me. Not a scientific test, I didn't pay attention to whether the tyres or pressures were the same.
22" GTS (with air) still way more comfortable than the Tesla Model Y I have, and I would say more comfortable than the new iX3 on 22's (whatever you read about it being super comfortable even with that size wheel, I'd say it doesn't compare to a Macan on air with 22's, GTS or otherwise).
twporscheguy
twporscheguy
San Francisco
Tesla Owner
lol, as long as it's more comfortable than the Y, then my expectation is, it's better than the S Plaid as well.
For those who had a chance to compare 4/4S and GTS - do you find the GTS makes the car less "wobbly" (what I mean by that is the 4/4s tosses you left and right when going on uneven surface)?
I find the suspension firmer but it reduces the wobbling effect which for me at least contributes to a more comfortable ride. This is something Kyle from out of spec noticed as well and I agree.
Overall I would say a great driving car which in terms of driving experience can make you rethink the Taycan.
Frenchboy
Nico
Seattle, WA
2025 Macan Turbo, 2018 991.2 GT3
I find the Sport suspension just right in my Turbo. Normal is a bit too soft for my taste. I used Sport Plus when I am ready for some extra fun and twisties.
How does the 10mm lower ride height compare to the "Low" air suspension setting, which is what I typically use?
MMR
The ride height is only different in Normal
The ride height in the other settings are the same
No_Wonk
Porsche Macan Turbo Electric
Almost sounds like GTS is a marketing gimmick then.
TS23
BMW G82 M4
This feels more like tires than anything else.
aks
Tony
Hertfordshire, UK
I had the Macan 4 for 2 days, then on a separate day drove the 4S and GTS the day back-to-back. The 4S felt like the 4 wrt suspension/ride, the GTS was noticably firmer as mentioned above.
Same wheels?
