engine runs while charging overnight
Trevasann
Trevas
Las Cruces, NM 88011
Porsche Macan 4EV
After the latest software update, I set my Macan 4EV to charge overnight, in my garage, for an 8 A.M. departure. Got up around 6am and heard the Macan engine running (sounds like climate control engine revving) but I could not turn it off. I tried everything but it ran until 8am. I only reached 287 SOC at 95%. Not sure what to think of this. Will try again before my return trip. Thanks, appreciate any feedback.
cooling for the battery while charging - it’s the fans to cool the battery
there is no engin to run while the car is stationary
FirstEV
Sweden
Not sure what you are referring to, but if you mean that you could hear some kind of “fan” from the outside of the car running at high frequency, that’s just the car cooling down the battery, especially if it is in warm weather.
Trevasann
Trevasann
Trevas
Porsche Macan 4EV
That makes sense, I live in the desert, so the garage could heat to 120*. I'd not thought of it but I'll try again, thank you,
Trevasann
Trevasann
Trevas
Porsche Macan 4EV
but if the fans are running all night while charging it will take a long time to finish the charge and it will not charge to capacity, right?
it’s fine the fans don’t use that much power
Normal for hot garage charging.
Target charging does not go miles 287/360 (that is a wild guess), it goes by SoC in %, so if you set it to 85% then it will reach it by the departure time assuming you plug it in to allow enough time to reach that target. As soon as the charging starts, you can see in the App when it will reach target charge.
yes, but I could only get to SOC 287 rather than 360+
the SOC is a guess and easily mislead - experienced EV owners ignore it
my Porsche 911 GT3 after a whole day on the track thinks I can only drive 107 miles on a full tank of gas - and it would be right if I was driving on track al the way home.
the SOC milage estimate is called the "guess-o-meter" and it's not to be relied upon - the only accurate measure of battery capacity is the % SOC…
the guess-o-meter is easily lead astray by recent driving consumption and has no idea what is going to happen in front of it…
if you want an accurate estimate of how far you can drive put your destination in to the PCM navigation and check the battery % at your destination…navigation knows about speed limits and elevation changes and likely consumption generating a much much more accurate estimate…
the SOC milage is simply a random number generator to be ignored when ever possible…
Trevasann
Trevasann
Trevas
Porsche Macan 4EV
Ok, only got to 94%. Fans draw electricity to run. Thank you
the SOC is a guest nd easily mislead - experienced EV owners ignore it
Thanks I need more experience with the PCM. I’ll make it a point to do that. Really good advice. Thank you so much.
And to be more precise, that's called range, not SOC.
SOC is the battery percentage.
Range (as displayed by the range meter, a.k.a the Guess-O-Meter) is the estimated miles the car will go based on recent driving speeds and patterns. (Which of course will vary greatly since most people aren't going to drive the same speeds and patterns every time.)
gwing
Garry
2026 Macan 4
I can attest to that --- previously I had a Volvo C40, and a Chevy Bolt before that. I could charge them on the 110V in my desert condo and they'd add a handful of miles overnight. With the Macan-4, in the desert in the summer, it picked up 1% after 5-hours. Awaiting installation of Level-2 charging and possibly some HVAC solution to cool the garage...
Trevasann
Trevasann
Trevas
Porsche Macan 4EV
Thanks for this, I'll try charging in the morning during our heat wave. Be sure to check with your local Electric company for rebates for charging after midnight and Level-2 installation.
rcomeau
Roch
Montreal, Canada
2019 Jaguar I-Pace
The fans take up negligible energy compared to the battery charging. Those fans likely mean that the cooling system is active (the fans cool the heat exchanger) which while consumes more energy, is needed to cool the battery while charging. Otherwise the battery can be damaged. If it is 120 in the garage, then I am not surprised that the cooling is running. Do you have any ventilation in the garage? All that heat coming from the cooling system has to go somewhere and if it just sits in the garage warming the ambient air (that is needed to extract the heat from the cooling system), it is less efficient.
