More comfort, smarter assistance and enhanced entertainment for the Porsche Macan
Towing enhancement (additional 500kg capacity to 2,500kg) can be retro fitted to prior model year vehicles.
Pulling this forward to find out more.
I've not seen anywhere about the new tongue weight for the updated towing specs - previously 200kg/440lbs (10% of the towing capacity)
I'm toying with looking at a small airstream - 16 or 20ft - that is within the weight limit, but has a tongue weight that is above 440lbs (eg the Airstream 20xe is over 500lbs). Would upgrading the tow package get me closer to being able to safely tow one of these?
I'm no towing expert but check the standard technical spec and you'll find
Electric Macan EV More comfort, smarter assistance and enhanced entertainment for the Porsche Macan Screenshot_20251104_091006_Chrome Beta
Indeed, but this data is incorrect, since the new towing package allows 2500kg now
Also the tongue weight is not in this document anyway.
An internet search doesn’t help as every Porsche dealer has posted the wrong towing data for the new GTS.
I’m in no rush, so I’ll wait until the data sheets are fixed
Is that not the noseweight of 100kg as per the image I posted above - GTS will be similar?
CHP
Christian
London UK
ex Macan 4S's
Here you go (GTS MY 26):
Length
4,805 mm
Width
1,952 mm
Width (including mirrors)
2,152 mm
Width (with mirrors folded)
1,954 mm
Height, air suspension (standard level)
1,613 mm
Height with roof rails, air suspension (standard level)
1,622 mm
Height, air suspension (off-road level)
1,643 mm
Height with roof rails, air suspension (off-road level)
1,652 mm
Height, air suspension (extra off-road level)
1,663 mm
Height with roof rails, air suspension (extra off-road level)
1,671 mm
Height, air suspension (low level)
1,603 mm
Height with roof rails, air suspension (low level)
1,612 mm
Height, air suspension (extra-low level)
1,593 mm
Wheelbase
2,893 mm
Turning circle (Performance Battery Plus)
12.1 m
Turning circle (Performance Battery Plus) (Rear-Axle Steering)
11.1 m
Unladen weight (DIN)
2,395 kg
Unladen weight (EC)
2,470 kg
Permissible gross weight
2,940 kg
Maximum payload
545 kg
Noseweight (EG)
100 kg
Max. towing load (braked)
2,500 kg
Max. towing capacity (unbraked)
750 kg
Maximum permissible roof load
75 kg
It seems the European Nose Weight is much lower than the US tongue weight. Presumably due to the difference in towing package construction - US does not have the hidden ball mechanism
In the US, the current weight is 200kg, for Europe it seems to be 80kg
And now I know that nose and tongue weights are the same thing!
CHP
Christian
London UK
ex Macan 4S's
Interesting but likely doesn't matter unless you transport gold bars in the frunk.
Length
4,805 mm
Width
1,952 mm
2,152 mm
1,954 mm
1,613 mm
1,622 mm
1,643 mm
1,652 mm
1,663 mm
1,671 mm
1,603 mm
1,612 mm
1,593 mm
Wheelbase
2,893 mm
12.1 m
11.1 m
2,395 kg
Unladen weight (EC)
2,470 kg
2,940 kg
Maximum payload
545 kg
Noseweight (EG)
100 kg
2,500 kg
750 kg
75 kg
Um, I posted this earlier...
pm4s
Never say never. Mercedes offered (200 GBP) dash cam functionality 3 years after GLE was released.
We need a 2026 Macan with working digital key to confirm.
If it works on 2026 but not 2025 (with comfort access/UWB option) it means either:
1) hardware is different (which h/w? best case scenario it's just the comfort access control module, easily swapped? but at what $$$$)
2) software is different (doubt it; makes zero sense)
I still have hope as:
1) I want it
2) can't think of what could be missing h/w wise
For example:
2025, Porsche Entry, ~950eur (No digital key)
2026, Comfort Access including Porsche Digital Key, ~1.200eur
Description is exactly the same for both options apart from the "Digital Key" part which costs an additional ~250eur (considering the functionality this is the most value for money option in the history of Porsche options, same price as the black paint on my 7 letter badge so I can read it from a distance more than 1m)
2025, Surround View incl. Active Parking Support, ~1.100eur
2026, Park Assist including 3D Surround View and Porsche Entry, ~2.800eur
Considering the massive price difference and very long list of extra features like trained parking, reverse assist, maneuvering assistant, kerb warning system, emergency braking function, etc. it is 100% obvious there is different hardware involved and I am happy not to have this as I understand the price difference and limitations of my hardware (cameras are pretty much unusable, never seen this poor quality video image, Porsche should have ordered from aliexpress/temu /shein, probably better quality)
FirstEV
Sweden
ex. Macan 4 EV (Delivery in October 2024)
1) I want it
For example:
Harsh, but yes. My 2018 Mercedes E-class had better 360 camera (front and rear as well) than Porsche. Felt like money down the drain *almost*.
CHP
Christian
London UK
ex Macan 4S's
[/QUOTE]
3D Surround view included comfort access. Price difference is around 400 GBP. Would be surprised if they would use two sets of camera systems but who knows.
One way to tell is to review the Owner’s Manual of the 2026 Macan. For that you will need to search the Porsche’s manuals with a 2026 vehicle’s VIN number. I had my VIN number assigned and available in the My Porsche app just before they started production.
Once the right Owner’s Manual is selected, check Chapter Overview > Technical Data > Radio equipment. If additional hardware is required for the Digital Key, it should be listed there.
seabird
Earth
Macan 4S, Audi RS5
There is no hardware difference. A UWB key is a UWB key whether it's a phone or a fob. The software is different. 2024-25 models don't have the digital key feature configured, but that's fixable.
The real problem is that Porsche is being Porsche and charging extra for the feature, which requires server-side activation and so has to be turned on or off for specific cars. There is no way for them (with present software) to charge existing customers with a post-sale option, and if they offered it for free to 24-25 models, then the rationale for charging for it in 26 evaporates.
So either they need to decide to make it a free/standard feature in the future or they need to build a "store" to charge the $300 or $400 or whatever.
