- First Name
- David
- Jan 28, 2019
- Santa Cruz
Service Complete - dropped off on July 31st - Returned Sept. 24th - OMG - there were many many delays {sigh} - mostly around ordering delays for a wiring harness and parts for the air supension
but it's back now - and I learned a lot living with a Macan 4 for 2 months…
Summary - What was done - high level overview
- Comfort access wasn't working - turned out to be rodent damage - non-warranty repair -grrrr
- Chassis Error - hmmm - replaced some parts and the airbags - not sure what was "wrong" but no errors now
- Recall: Backup Camera
- Recall: Recode the headlights
- Recall: Software update VR28.11
- Recall: Rear motor wire harness washer check/repair
- Concern: Driver's door comfort access was no longer working
- resolution: rodent damage - had to replace/repair a wining harness - not warranty {sigh}
- VAL PERFORMED IN LINE 3. FOUND CODES "B1D6013 - Rear left KESSY antenna (R165), open circuit", "B193313 - Front lid proximity sensor (G1036), open circuit". REMOVED DOOR SILL TRIM ON DRIVER SIDE, NO DAMAGE TO THE ANTENNA, WIRES AND CONNECTOR AND GOOD. REMOVED FRONT TRUNK TRIM. FOUND RODENT DAMAGE TO BOTH WIRES TO THE LEFT REAR KESSY ANTENNA. LOOKING AT THE FRONT LID PROXIMITY SENSOR, FOUND RODENT DAMAGE TO THE HARNESS FOR THE SENSOR IN THE BUMPER. RECOMMEND WIRE REPAIR FOR ALL RODENT DAMAGED WIRES. PERFORMED REPAIR IN LINE 11. This is a diagnosis line only
- REPAIR WIRES FOR LEFT REAR KESSY ANTENNA, ABOVE LEFT FRONT WHEEL, AND FRONT LID PROXIMITY SENSOR, BUMPER NEEDS TO BE REMOVED. AS PER CUSTOMER REQUEST REPAIRED WIRES FOR LEFT REAR KESSY ANTENNA AND FRONT LID PROXIMITY SENSOR, CLEARED FAULTS AND ENSURED ALL KESSY FUNCTIONS WORK AS DESIGNED. CUSTOMER COMPLAINT REMEDIED AT THIS TIME
- Concern - Chassis Error - no air supension control for 4+ days - then it cleared…
- resolution - I"m not quite sure but they did some things…
- PERFORMED VAL AND SCANNED FOR FAULTS AFTER CONFIRMING WARNING LIGHT. FOUND CODE "C1401F0 - Air supply system - internal communication error". CHECKED FUSES F36 AND F62 FOR J1075 IN LEFT REAR FUSE BOX. FUSES GOOD. CHECKED LEFT REAR GROUND POINT 50.1, GROUND POINT GOOD, TORQUED PROPERLY. REMOVED REAR UNDERBODY PANEL AND LOOSENED LEFT REAR WHEEL HOUSING LINER TO CHECK COMPRESSOR. NO DAMAGED OR LOOSE CONNECTORS FOUND. TESTED CONNECTOR B FOR COMPRESSOR CONTROL UNIT J1075.1. FOUND 14V ON SUPPLY, REAR RAISING SIGNAL, HECKTESTER SIGNAL REDUNDANT, LED, ABSENKEN. 2.4V FOUND ON CAN HIGH AND LOW. GROUND POINT, NO OPEN CIRCUIT FOUND. FOUND CONTROL UNIT FAULTY, REPLACING CONTROL UNIT. REPLACED CONTROL UNIT AND PERFOREMED CODING/ PROGRAMMING, FAULT STILL PRESENT. FOLLOWED GUIDED FAULT FINDING AND ORDERED COMPRESSOR FOR AIR RIDE. REPLACED COMPRESSOR, COMPRESSOR WITH CONTROL UNIT (PREVIOUSLY ORDERED CONTROL UNIT RETURNED). PROGRAMMED CONTROL UNITS AND FILLED AIR SUSPENSION, WHILE SCANNING VEHICLE TO CLEAR FAULTS, REAR AIR BELLOWS FAILED AND BLEW. ORDERED NEW BELLOWS, WEEK 38 REPLACED COMPRESSOR, COMPRESSOR WITH CONTROL UNIT (PREVIOUSLY ORDERED CONTROL UNIT RETURNED). PROGRAMMED CONTROL UNITS AND FILLED AIR SUSPENSION, WHILE SCANNING VEHICLE TO CLEAR FAULTS, REAR AIR BELLOWS FAILED AND BLEW. ORDERED NEW BELLOWS, WEEK 38. NEW BELLOWS INSTALLED AND AIR SUSPENSION FILLED. FOUND NEW COMPRESSOR AND ITS CONTROL UNIT WERE CODED WITH A DIFFERENT VEHICLE IDENTIFICATION NUMBER. CORRECTED ERROR, PERFORMED RESETTING VALUES OF COMPRESSOR AND RIDE HEIGHT CALIBRATION. AXLE LOAD CALIBRATION AND AUTOMATIC CODING. LET VEHICLE REST AND KEY CYCLE TO CLEAR FAULTS AND TEST DROVE VEHICLE 6 MILES, KEY CYCLED VEHICLE AGAIN. SHOP ASSISTANT TEST DROVE VEHICLE TO ENSURE REPAIR. CUSTOMER COMPLAINT REMEDIED AT THIS TIME.
- RECALL: 99POZ-ARC5 RECODE HCP4 C.U.
- ARC5 recall campaign Re-coding main control unit for body electronics (HCP4) and control unit for headlights Re-code main control unit for body electronics (HCP4). For vehicles with country-specific equipment C36 Canada, the control units for headlights (MX14, MX15) and the control units or auxiliary headlights (MX1, sMX2) must also be re-coded. Information The minimum programming requirement is PIWIS Tester software release 43.000.040 (or higher). Information The prerequisite for this action is the successful implementation of the campaign WRM0 Update to software network VR28.11. If software network 28.11 has not yet been installed on the respective vehicle, this must be done before carrying out the present action here. SCOPE 1 74TU, SCOPE 2 74TU ARC5 recall campaign Re-coding main control unit for body electronics (HCP4) and control unit for headlights PERFORMED SCOPE ...1 VOLTAGE ...14.7
- RECALL: 99POZ-ASA3 REVERSE CAMERA C.U.
- ASA3 Re-Program Reversing Camera Control Unit and, if necessary, Replace Reversing Camera and Surround View Cameras (Recall Campaign) In rare cases, the reversing camera of the affected vehicles cannot be activated when ParkAssist is switched on due to a software error. In addition, with a very small number of affected vehicles, it is possible that the housing of the reversing camera and individual surround view cameras in the surround view equipment option were not bonded as per default value specifications. As a result, no camera image is displayed in the central display when ParkAssist is activated contrary to the default value specifications. If the camera housing is not bonded correctly, moisture can penetrate and impair the camera image. Action: Re-program reversing camera control unit using the PIWIS Tester and replace reversing camera and individual surround view cameras if necessary. Each vehicle was assigned exactly to one scope that includes the actions required for each vehicle. PIWIS Tester software release 43.300.040 (or higher) SCOPE 1-127TU, 2-25TU, 3-230TU, 4-556TU, 5-271TU, 6-271TU, 7- 597TU, 8-597TU, 9-312TU, 10-639TU ASA3 Re-Program Reversing Camera Control Unit and, if necessary, Replace Reversing Camera and Surround View Cameras (RecallCampaign) Performed scope 2 voltages at 14.7
- RECALL: 99POZ-WSD0 SOFTWARE VR28.11
- WSD0 - Install Upgrade to the Software Network VR28.11 (Workshop Campaign) Additional software optimizations are available for various control units for the Macan Electric. An overview of the changes that will be implemented with the software update can be found in the appendix under ? Technical Information 'Overview of software update changes'. Action: Perform reprogramming of the affected vehicle using the PIWIS Tester on the incremented software network VR28.11. Information The minimum programming requirement is the PIWIS Tester software release 43.300.010 (or higher). Information The prerequisite for this action is the successful implementation of the campaign WRM0 Update to software network VR28.11. If software network 28.11 has not yet been installed on the respective vehicle, this must be done before carrying out the present action here. Read TI WRM0 for details on this. SCOPE 1 147TU WSD0 - Install Upgrade to the Software Network VR28.11 (Workshop Campaign) PERFORMED SCOPE 1 VOLTAGE ...14.7
- RECALL: 99POZ-WSJ2 WIRE HARNESS
- WSJ2 Reworking Rear Axle Module Wire Harness (Workshop Campaign) On the affected vehicles, it is possible that the diameter of the fastening clip of the rear axle module wire harness does not meet the required specification. If this is the case, crushing and damage to the main wire harness cannot be ruled out. As a result, a yellow warning message Vehicle electrical system faulty will be displayed on the instrument cluster. Action: Rework the rear axle module wire harness SCOPE 1 57TU, SCOPE 2 77TU WSJ2 Reworking Rear Axle Module Wire Harness (Workshop Campaign) PERFORMED SCOPE 1
- Check Tire pressures
- Dealer full vehicle inspection
- Loaner Car was provided (Macan 4 EV)
