Yes, a team of Porsche engineers from Germany are flying over to my house for proper diagnosis of the issue. They are confirmed for a visiy next Tuesday 8 AM for a full day of diagnosis and hopefully a solution.
Fingers crossed i am sick and tired of having to waste time charging a car at a DC charger which I don't even drive...
this is the most fascinating post on this entire thread - I'm watching with great interest
SandyHaus
Sandy
Denver, Colorado
2025 Macan 4 Electric
Wow! I'm going to go right out and see if my car has healed itself. Not hopeful since I try it nearly every day just to see if something's changed. Inconsistency like this is even worse that consistently bad.
Sandy
I’m quoting myself here because after this flippant remark, I went to my garage and, after weeks of my 220v Tesla charger giving errors every time I tried to charge, and having to use the 110v “switcheroo” procedure to charge at home, I plugged in to the Tesla wall charger this evening and — it started charging right away.
So, 1) It’s healed itself, or 2) a magical OTA update has been pushed into the car (least likely), or 3) some condition (voltage, current, temperature, barometric pressure, etc. or combination thereof) has changed to allow this to happen.
Not sending my 110v voltage regulator back just yet.
Sandy
Dandar245
Dan
New York, NY
Porsche Macan EV 4, Audi SQ5
I think i spoke too soon. After about a 30 mile drive for dinner and arriving back home, I tried one more time just to confirm and it was not working again. Its worth noting the temp had fallen back into the mid to low 30s and was upper 40s to lower 50s when it was working earlier today. I guess I'm keeping my service appointment for next week.
ScottM
Scott
Chicago
25 Macan EV Turbo & 25 Cayenne GTScoupe
I just received an update from my service advisor, who heard back from their field engineer. The word is that we should supposedly have a software remedy within the next two weeks. I’ll keep the thread posted as I hear more.
someTimesJoe
Joseph
Tri Valley, Ca
Taycan CT 4S, Macan EV 4S
First time charging after the update failed but plugging it back in again, it charged. Tried it again tonight and took about 8 attempts before it charged. I swapped out the Porsche’s mobile charger 14-50 plug to the 110 and it took on the second attempt. Unplugged it right away and plugged in my Tesla wall charger and it maintained the charge at 40a.
Scheduled an appointment for service and it’s a month out. Hopefully a fix will be available by then.
sbs
SBS
PA
2024 Macan EV
sbs
SBS
PA
2024 Macan EV
Adding my car to the list of issues
2024 Macan 4S
Got the latest update installed mid December and then was travelling for the last two months. I came back and it was not charging at home. When I took it to the dealer they first said I was using the wrong Porsche Charger (it was the one I have been using since I got the car - my 2021 Taycan charger). Regardless, I sent over the 204 charger. I have two separate 40A circuits at home and tried the AC/DC sides no luck. I have a Juicebox that charges my Tesla that was working on the Tesla but no dice on the Macan.
It charged at the dealer and they have given it back to me. I brought it back today and obviously having the same problem. I have just tried the departure time hack and the car is flashing blue, saying charger paused. Will check in a bit. And also try the 110v charger as well.
I will call the dealer on Monday. Also will go try a fast charger near my home tomorrow.
Sucks
sbs
SBS
PA
2024 Macan EV
2024 Macan 4S
Sucks
Quick update - the departure time hack seems to be working ... for now
this is pure golden 100% dealer service BS - this simply shows how little they actually understand what an EV Charger (EVSE) actually does and how it works…OMG this frustrates me soooooo much…
what they basically were telling you is that you're using the wrong on/off switch…which is simply ridiculous when you put it in those terms…which is in fact what an EVSE actually is - it's an on/off safety switch under control of the vehicle's OBC (on board charger) - and there is no such thing as a 'wrong EVSE' - they are STANDARD by design so that you can use public and private chargers regardless of who made the on/off switch.
OMG - soooo much BS!!! sooo frustrating - they are grasping at straws in order to avoid the logical conclusion that their software update is causing problems - because they understand how much of a f'up that is and how embarrassing it's actually going to be to have to recall all those cars again to fix the problems with their latest update…
https://www.macanevowners.com/forum...-common-misconceptions-what-is-an-evse.22275/
jergans
NY
Macan EV Turbo
My car has been sitting for a week. I’ll run it for a bit then try again. If there’s no solution, then it’s possible that the onboard charger is the culprit…which would explain why my car charged fine after the update, then stopped working all of a sudden.
I’ve posted in this thread a few times, but I’m now nearly certain that I have a DIFFERENT charging issue. My car was not able to charge at the dealership. Others experiencing the charging issues in this thread have successfully charged at this dealership. Will update with whatever they find.
annwills
Bill
Orchard Park, NY
2025 Porsche Macan 4S
BRILLIANT! It was just a matter of time before a dealer experienced the same location-specific inability of the Macan to tolerate normal North American electrical supply variations that others have experienced. Keep us informed of what excuses they come up with.
jergans
NY
Macan EV Turbo
I don’t believe my issue is software related or related to any kind of voltage situation. I think my car’s onboard charger may have failed. But will keep you posted.
anyone know if hotel level 2 chargers will work on our broken cars?
it will depend on the voltage - it's NOT the charger that's the problem - it's the voltage from the grid that is causing the problem - it's not the charging hardware - it's the power supply being fed to the charging hardware…
so it may or may not work depending on the grid voltage at the time you plug in.
_THIS_ is the problem with this issue for all updates Macan's - even if your Macan is working at your home - it's no longer a reasonable assumption that when charging away from home that will actually function…grid voltage can vary by neighbor hood - you might be able to charge at home, but not at work, or not at the hotel 200 miles away from your home on a simple road trip…
this has taken simply, easy and straight forward 240V/L2 charging and made it a crap shoot as to if it will work - it's a serious problem…
grid voltage varies - it's like the weather - it's an environmental factor
the bottom line is that as long as this "bug" is out there you may or may not be able to charge an updated Macan EV at any 240V/L2 AC EVSE in North America…it's now "random" as to if charging will function for any given location…good luck!
I alluded to this in post #288 - https://www.macanevowners.com/forum...ate-tracking-thread.24560/page-16#post-373818
as long as this bug persists you can no longer travel with a Macan EV to locations in North America and make the reasonable assumption that 240V/L2 charging will function…which will strand you someplace next to a functional 240V/L2 EVSE - but your Macan will fail to initiate a charging session because the grid voltage at the moment in time is 0.5 volts "too high" for the new software - which is something you as the owner of the Vehicle can do _N O T H I N G_ about…I hope you have enough battery left to drive someplace else to attempt to charge … or can wait 10+ hours to see if the voltage changes and lets you charge again÷
Macan 4, Macan 4
I would never arrive at a hotel with insufficient charge to be able to get to a DC charger. The hotel chargers could be occupied or inoperable. Typically, I go to a DC charger before going to the hotel. If I don’t for some reason, then I want an SOC sufficient to go to a DC charger in the morning.
someTimesJoe
Joseph
Tri Valley, Ca
Had a short road trip this past weekend which I could have used EA or Tesla SC if needed but luckily I didn’t have to. The Charles Schultz Museum (great little place if you’re a Peanuts fan) happened to have Chargepoint station. I was successful on getting a few hours in at a constant 6kW upon plugging in, no errors.
No back home, I can’t get anything going again. Will give the 110 another try then switching.
