Easy Entry Operation is Inconsistent
brads
Brad
Toronto
2025 Macan 4
My wife and I have been having an inconsistent experience with the Easy Entry function i.e. position of the seats, mirrors and steering wheeling adjusting to the settings associated with the key fob used to unlock the car. My wife and I have quite different seat settings so this feature has been welcome on many of our previous cars.
We typically park our MY25 Macan 4 two levels underground. Easy Entry fails to work about one third of the time i.e. seats remain in the position of the other driver if a different driver has unlocked the car. When changing drivers outside where there is strong wireless, the feature has always worked.
My theory is that the feature requires that the car have a wireless connection in order to operate. The wireless connection is weak and unreliable where we park our car in our underground parking garage.
Does anybody know for certain if a wireless connection is required for Easy Entry to work? I asked the Service Advisor at my local Porsche Centre but they didn't know.
pm4s
What do you mean wireless connection?
The 5G mobile network network for PCM?
Why would that be required?
The ergonomic settings (seat, mirrors, steering) are saved each time when you switch off the car (Porsche calls this switch off "readiness" mode) to your profile linked to your key.
Your profile is automatically selected when you unlock the car.
On you door you also have 3 memory settings for the ergonomic settings which you can save with the SET button.
If you have 2 profiles you have 6 memory settings that you can use in total.
That's in theory.
In practice it's different, my guesses are:
1) Porsche/AAOS software is crap (which is a fact) so 100% success rate is impossible.
2) Both you and your wife reach the car with both keys cars selects "wrong" profile (50% chance) You can verify the profile and even change it in the PCM (although takes an eternity and the system looks like it's having a meltdown while doing it (refer to point 1 above)
3) After wrong profile is selected you or your wife adjust the seat using the controls, the "wrong" settings are now saved when car is switched off and now the correct profile has the wrong settings until they are manually changed and saved again...
No_Wonk
Porsche Macan Turbo Electric
I'm the only driver for the car and I found the steering wheel doesn't fully automatically adjust. (it has to move a bit lower) so I hold down the 1 button before driving usually, in additional to changing to sport mode because defaults to normal when I first start the car.
brads
Brad
Toronto
2025 Macan 4
Yes
I don't know if it's required. It's a theory based on what I've observed. It's worked both times I went to the Porsche Centre to have it looked at. It works when we're outside. The problem only seems to happen when the car is parked at home, which is two stories underground.
My question is whether others have knowledge on how this feature works that might explain what we're seeing. My Service Advisor is stumped.
I'll clairfy the scenario:
  1. My wife returns home, parks the car underground. The seat is in her position. She was driving with her key.
  2. Later, I go to drive the car alone, with my key. About two-thirds of the time, the car will correctly adjust the seat. One-third of the time, it remains in my wife's position. In all cases, my profile comes up in the PCM.
  3. This also happens in the reverse scenario i.e. my wife getting in to the car after I've driven it.
This is an interesting situation. I'll watch more closely for it.
I’ve found that it takes a LONG time to switch profiles. Combined with the safety system where the seat won’t move to a saved position if you’re not holding the button when you’re sitting in the seat, could it be that you being in the car when it comes time to set the seat position stops it moving
I’ve given up on this feature and just press the 1 button when getting in - the seat moves freely if you’re outside the car with a single press of the button
With Comfort Entry, the car needs to load the driver profile associated with the key fob used.
Historically and before the cloud and connected car shenanigans it was very much keyfob driven.
My guess is that as the car also logs in with the Porsche ID associated with the fob it must first authenticate which requires a cellular connection (unless cached credentials can be used) from the car to the cloud. If this connection isn't available and the fob used is different to the last one used then the settings won't change. It may be that a subset of settings are available rather than all.
Having both fobs present at the same time can also present a separate issue.
brads
Brad
Toronto
2025 Macan 4
Yes, this is my theory.
I'm hoping to confirm or refute this to avoid a third, wasted trip to the dealer.
I think my next step is to push my Service Advisor to seek an answer from her support network i.e. Porsche North America or the home office.
brads
Brad
Toronto
2025 Macan 4
I did hear back from Service Advisor and she was able to confirm that Easy Access does require that the vehicle has a connection to the internet (i.e. 4G/LTE/wireless). Unfortuantely we'll have to live with the intermittent reliability of this feature.
cogtooth
West Virginia
Volvo XC 40, Macan 4S
How do you turn it off? Some of us have had luck never touching the on/off button. Put the car in park (or not), and just open the door and get out.
brads
Brad
Toronto
2025 Macan 4
I use the on/off button. I find that if I put it in Park, the door handle often takes more than one pull to open, a safety feature I suppose.
To be honest I'm still skeptical as that would mean the feature wouldn't work if your optional Porsche Connect (provides cellular data service amongst other things) subscription had expired. It would also make it operate differently to other Porsche models. Owners manual makes no prerequisite conditions either if it truly had this somewhat limiting dependency.
I still think the settings are held locally / cached on the PCM once set per key fob for rapid recall.
Imagine the delay in opening the car door if first a 4G / 5G connection had to be made to acquire comfort settings - it would take quite some time (the car has to wake up first). Current tardiness of My Porsche App to make a connection to the car is evidence of that - lock / unlock, sounding horn etc.
Degenatron
I had this issue too, but since the update VR28.13 it has behaved itself and changed profile/seat position each time, although sometimes with a delay after I've got into the drivers seat.
Not usually parked underground, I'll have to test it when next out of cell range.
Also echo how long it takes to change driver profile, about 1 minute sometimes - what is it doing in all that time that take so much horsepower? Inefficient software most likely.
beez
B
Macan
There is also a PCM setting for which is the primary driver. I think this is for when you both enter the car with your respective keys.
Dragon Tourniquet
Nevada
The annoying thing about the 2 keys / users part is the key uses UWB, so they can easily detect which key is closest to the driver seat and select that user, but they don't.
Inefficient due to poor cell connection probably.
