  • Total voters
    97
dimaa_6abc
Kyiv, Ukraine
Macan EV 4S
Mine was updated in early May 2025, since then it was updated sometime in October, especially high voltage battery was updated, and I indeed see at least one change - before, the car would not stop the AC charging session when target SoC is reached, after the update it terminated the session as the other EV would. And currently I don't have SoC drop, but maybe a long trip with rapid charge sessions will bring this back.
EVowner, your case is the worst I have seen, definitely something is not right. Our PCM screen went black only once is 16,000km. And if the car refuses to accept 11kW AC charge, I believe the dealer must do anything to fix that, as it is so obvious and easily reproducible.
ChrisFromUK
Mines been in the 1% club since delivery in April 2025. Just checked and its already 2% down since I parked it 50 hours ago.
The big software update in November didn't make any difference to this behaviour.
However, the update did seem to introduce a different layer of madness with the SoC level which can now change quite significantly (up to 5%) over short periods (couple of hours to a couple of days), more often than not downwards but upwards also. This is quite possibly the battery pack cells being unbalanced but I have run down to 2% and charged up to 95% a couple of times which has only helped slightly. It was also reporting zero miles range at 10% SoC last time I ran down to 2%.
I'm going to have a chat to the dealer about this again next week as I need to book it in to get a dashboard vibration/rattle fixed.
platypus
New York
'24 Macan Turbo Electric
What’s “reassuring” in a way is that we’re all experiencing the same symptoms, so it should really be on Porsche’s radar at this point.
EVowner
Macan 4s
Just to be clear as I stated before all the issues are completely random. There are days when car is not dropping SoC and then there are days when it starts dropping SoC and continues to do so at various rates across multiple days. Same with that AC charging. It works fine most of the times, but then multiple charge cycles it just start charging at half of the speed until I stop the charging if I am near the car, replug it and then it works fine for rest of the cycle. I don't believe that it is caused my charger as it worked just fine every single time with loaner Macan.
As I said before I believe certain conditions are triggering this behaviour, but I have not yet figured out what are those. On one hand with all the stuff that my particular PCM is doing I would say that car sometimes just refuses to go to sleep properly and it is computer or some HV module draining the battery which would be in line with other people saying that they think this started happening for them after SW update.
Issue with that SW theory for me is that mine did first SW update in September. My car was produced in June 2025 so at this point it was 2 months old and with around 3K kms. At that time I was already complaining about planner saying that I will arrive with higher SoC than at the start of the journey, car being unable to hit charge limit (always higher or lower SoC then limit), music stopping randomly, blind spot monitor seeing ghosts and rain sensor not working at all (at least this one thing was fixed on first try, with service center stating that it was not seated properly from factory). Whether it was draining already at this point I honestly cant tell as I was using preconditioning often. Service center said that they already saw issue in diagnostic with HV system before doing the update and even at that first visit they were doing something with battery/BMS module (I guess first recalibration of battery as unexpectedly they called me that they need to keep the car overnight and actually returned it to me just before closing next day with them stating that they were working on it till last minute). So this would mean that on my car at least something was wrong with HV system even before any SW update. Also if it would be SW caused why is it affecting only some cars? Maybe some specific combination of equipment in the car and mine came with some faulty SW build from factory?
On the other hand fact that service center saw poor SoH and recalibrated my battery, if what they are saying is true, already so many times tells me that they are getting either constantly strange readings from it or they really don't have any idea and are just trying it over and over again as it is the only thing that they can do (I heard from various sources that service centers see between 30-40% of data in diagnostic and everything else is visible only to Porsche, which sound absurd, but from my experience I tend to really believe it at this point). Like somebody pointed out losses are real as battery is happy to accept charge again, so maybe issue is really in the battery itself? I know Porsche is starting to produce their own batteries with Cayenne EV and I saw them stressing out that they will now thanks to that have much better QA which would maybe point to them knowing that their battery supplier is not very good. That would be in line with many Taycans getting quietly battery swaps these days (luckily their owners can at least see state of their batteries themselves thanks to the tCAN SW). This would technically also explain why, so far they are pretending, as seen on this forum from experiences of others with their service centers, that the issue with discharge on Macan does not exist as replacing batteries on almost brand new cars would be quite expensive problem for them. But I don't want to speculate.
All I know that every day I see more and more owners (not only here in various different threads, but also on various FB Macan owner groups) seeing same issues that I have been seeing for months which on one hand is reassuring me that I am not crazy, but on the other hand I don't think there is a known real fix or even not publicly disclosed known issue to dealers by Porsche, as my dealer is already at the point of discussing potential replacement with me. Scary thing is that there seems to be zero guarantee that new car wont start doing the same thing one day...
MacanEVOwner
Cody
Maryland, USA
2025 Macan 4S EV (former 2022 992.1 S); Polestar 2 EV
Just curious, but who is “we’re all experiencing the same symptoms”?
It should be noted that after a re-charging session…to 80% or more, it;s NOT uncommon that for the next day, or two one will experience charge re-distribution on the battery…This is normal, and with the re-distribution, one can see a few % drop in the SoC as seen on the driver’s screen. As explained by Google AI:
Key Aspects of EV Charge Redistribution & SoC Changes
  • Voltage Relaxation (Battery "Resting"): After you stop driving or finish charging, the battery is in a non-equilibrium state. Lithium ions are not evenly distributed within the cells, and the voltage is temporarily high (after charging) or low (after driving). Over several hours, the battery relaxes to a true equilibrium state, which can make the SoC percentage tick up or down slightly.
  • "Vampire Drain" or Passive Drain: While the chemical redistribution is happening, the car's Battery Management System (BMS) is still active. It uses electricity to maintain the battery, stay connected to the app, or run security features, which causes a steady, small, and real decline in SoC over time.
  • Temperature Effects: Cold temperatures cause the battery to become less efficient. The BMS may activate heaters to protect the pack while parked, consuming power and reducing the reported SoC.
  • Typical Behavior: Many modern EVs experience a small, normal loss of 0.5%–3% of charge per day when parked, commonly known as "vampire drain".
    ScienceDirect.com +4
Why This Matters
  • Inaccurate Estimates: When you park after a long drive and see 30%, you might return a few hours later to see 28% or even 32% as the battery equilibrates.
platypus
New York
Fair question. Here's the pattern that keeps showing up across multiple owners (I asked Claude to help):
  • Sustained 1%/day drain over weeks, not a one-time adjustment after charging
  • For many of us, it started after a specific SW update (byebye: fine for months, then 1%/day after Oct 2025. Dekord: zero issues for 6 months, then 1%/day after May 2025 update. Mine started after a June 2025 dealer visit)
  • Dekord noticed that when drain is happening, battery temp is 3-4°C above ambient, suggesting the BMS is actively doing something. And below 30% SoC, the drain stops entirely and temp drops to ambient. That doesn’t look like voltage relaxation.
  • Multiple owners (M324, EVowner) confirmed their loaner Macans had zero drain under identical conditions. Same charger, same garage.
  • BMS resets haven't fixed it (craz8 confirmed).
In my case, the car is plugged in. It charges back from 78 to 80% every couple of days. That's real energy being pulled from the grid, roughly 1 kWh/day disappearing somewhere.
EVowner's case is clearly more severe (12% in 10 hours, 91% SoH after 6 months), which looks like a hardware problem on top of whatever BMS bug the rest of us have.
My current guess: a SW update broke something in the BMS sleep cycle. It keeps doing balancing or thermal work instead of going to deep sleep, which would explain the suspicious timing, the elevated battery temperatures, the threshold at 30%, and why loaner cars (possibly on different SW versions) don't have the issue.
MacanEVOwner
Cody
Maryland, USA
Good analysis.
Mine did not start with a software update, but otherwise I agree.
I suspect that low usage - periods of no driving, and/or, lots of short trips - cause something to get confused in tracking SOC which then triggers the BMS to work too much. When I was driving longer trips last year, I did not see this problem
The key thing to measure this is to do it over several days. Due to shutdown usage, ongoing cooling, 30 minutes of powered on accessories, and correct BMS balancing after a drive or charge, a single night's loss or change is entirely expected.
However, the only way to see the change is to go to the car, open it up, and turn it on. The app can't tell you the car battery status over time. Each time you turn the car on, it will restart some of those shutdown activities, so you can't measure daily with the car displays.
I think this failure escalates to needing a BMS reset, and might also cause excess battery work that ends up with the bad cases some here have hit.
I have reported this to my service guy as a note that will likely turn into something. Those of us with the issue need to report this to our dealers to give Porsche a chance to see these reports. If anyone knows how to report a technical issue to Porsche USA directly that would help too.
The Audi PPE cars might be having similar problems, but I have no idea where those folks hang out - having a known problem in that group would help get Porsche focussed on a fix for us.
I have a different monthly usage report that is much better suited here.
I completed my BMS calibration on March 3 at 100%. Since then, I've driven just 84 miles at 2.8 miles/kwh across 16 trips. This morning, my battery SOC was 32% when I turned the car on.
With 84 miles at 2.8 kwh giving 30kwh used for travel. I should then have close to 70% SOC remaining (some losses from pre-conditioning and post-trip usage would take a bit more, so maybe 65%). I have lost about 35% SOC over the month.
I will let it go under 30% to find out if this does stop once it's below 30, as suggested above. That would be a good data point. Then I'll charge it back up to a high charge to be able to measure the actual kwh used to ensure this isn't a measurement problem, and is actually a power drain. And I'll drop a note to my service advisor.
Today it dropped from 39% on Friday to 32% on Wednesday - I'd have been happy with the initial 38% displayed in this short video!
Dekord
Slovenia
Macan 4, BMW iX1
Battery discharge does not stop on its own. Battery discharge can only be stopped by starting the car, so that you can at least get in the car and then get out. My observation is that the battery does not always discharge when the car is stationary. As a rule, it almost always discharges when the battery is more fully charged. The more discharged the battery is, the less likely it is that it will discharge after parking. However, there is no rule. Discharge is also accompanied by a higher battery temperature of 3 to 4 degrees. Waking up the car via the application does not affect discharge. Something heats the battery and energy is used to heat the battery. This occurs both in summer and winter and does not depend on the outside temperature. In one week, it can discharge by as much as 7% if the battery has a temperature 3 to 4 degrees higher than the ambient temperature, or 0% if the battery temperature is the same as the ambient temperature. Conclusion: The battery discharges if the battery temperature is constantly higher than the ambient temperature, something is heating it. The battery does not discharge if the battery temperature is the same as the ambient temperature, the battery does not heat up. It is necessary to find out what is heating the battery while it is parked, so that it loses energy. I came to these conclusions because I have my car in a garage, where the temperature changes very slowly. When I get into the car, I can compare the temperature of the battery and the temperature in the garage. When the temperature is the same, the battery does not discharge, when the battery temperature is 3 to 4 degrees higher than the temperature in the garage, the battery discharges. If anyone from Porsche reads these notes, I ask them if it is really that difficult to find out what is heating the battery while the car is stationary. In addition, there is also the inaccuracy of displaying the battery charge, which further complicates the matter.
@Dekord
Interesting observations about battery discharge.
It's definitely certain the spontaneous battery heating while the car stays parked and unused is directly related to the % SoC loss.If we only could find out why is this happening we would have the solution to this so much stubborn issue.So the real question is: Why the car is triggering on its own the battery heating even when there's absolutely no need for the battery to be heated in the first place.
EVowner
Macan 4s
For those wondering I checked both Q6 and A6 discussions and was able to find so far only these two posts:
2025 A6 e-tron Quattro Losing Charge and Cruise Control
Battery State of Charge Dropped 30% in an instant--has anyone else experienced that?
No idea if they managed to solve it or if it is indication of same problem. TSB attached in second post mentions that fix is rebalancing individual battery modules which is what my dealer has been doing since day one.
As for the battery temp raising theory. While I noticed this myself on few occasions and I even pointed it out in my previous post in this thread as either:
  • Car heating battery willingly - According to Out of spec video Macan can initiate discharge of the battery if it's charged to high SoC levels and the outside temperature is high. Guy in the video speculated that this discharge might be done by car heating the battery, which I believe is false, because battery saving function in manual specifically states that it is cooling battery and it is also quite logical to cool battery instead of heating it if outside temp is already high. Either way this discharge should be triggered after 90h hours of car being stationary in hot temps.
    Electric Macan EV Does your Macan EV keep SoC stable when left idle for a week or longer? Macan SOC 32
    I was unable to find any info whether car can also initiate battery heating when it thinks that battery temp is too low. Since I have seen battery temp being close 0C in winter I don't believe that there is such function. Car can definitely start heating the battery in preconditioning mode, but that is tied to navigation set to DC charger or car being driven in Sport Plus mode. That said seeing how Porsche SW works I don't think it is out of realm of possibility that there can be some bug that can somehow trigger battery heating randomly.
  • Battery just loosing its energy on its own by some chemical reaction that results in generating heat - As pointed out by others including myself car seems to be unaware of battery being drained until the moment its turned on which would be in line with battery doing something that car is not aware of. This could also explain why mine battery needs so much rebalancing, because if some cells are faulty and cant hold charge properly they can constantly be taking battery out of balance.
  • Battery is powering something that is not shutting down properly and consumption of energy is heating battery - This would explain why battery temp raises only slightly and also randomness of SoC drain.
I can't honestly confirm that every SoC drain on my car is tied to battery temp increasing. That said it is also possible that me seeing same battery temp when SoC drops is just car heating the battery which would normally be going colder.
Either way I can 100% confirm, as Dekord stated, SoC drain is not happening all the time. Like I mentioned before there are days or sometimes even weeks when SoC is stable. Then out of sudden SoC drain is triggered by something and it is continuously happening over multiple days. On my car there are also PCM issues/slow AC charging issues that are triggered in similar random fashion. They don't seem to be happening at the same time as SoC drain, but nevertheless they lead me to believe that there is some common culprit here, because it is too many faults for them to be unrelated.
EVowner
Macan 4s
Looking around this thread I stumbled upon link to another where I found somebody claiming that Taycans will trigger their own battery rebalance if BMS detects imbalance. A little bit more googling and I found this post on Reddit about Taycans which seems to fit the bill perfectly:
Electric Macan EV Does your Macan EV keep SoC stable when left idle for a week or longer? 1775258024098-8
So I guess there is something wrong with our batteries and their cells gets out of balance way too often or BMS has some sort of problem and it is triggering this rebalancing even when not needed. If this is really the case even for Macans I will be really pissed off, because there is no way that Porsche is not aware of this since it seems to be a feature of their BMS.
This is simply that the car doesn't monitor things constantly, since the 12v would drain quickly. It's annoying when trying to track these things down, but not a symptom of a problem.
My car has not been above 20C or below 10C in the last month, losing 30% during this time, and most of that lost below 80% SOC, so this process doesn't apply - OR IT SHOULDN'T! A bug could be that this is triggering when it shouldn't. I think this is less likely, but not impossible.
For me, until today, it was. Today I lost nothing over 2 nights, but my battery temp was higher than the garage temperature this morning! I'm at 32% SOC now, and this is the first time I've not lost SOC across 2+ nights since the last charge. 32% might be close enough to the self balance stop point to be interesting (for the Macan, it might stop at a higher SOC)
The symptoms mentioned in that Audi TSB are not ones I've experienced after the SOC recalibration. My range display was way off before the recalibration - but no sudden loss of range in that display occurred.
I do think this is a BMS self-balancing problem - either a software bug where it's confused, or a real problem with a cell triggering the process.
