  • Total voters
    87
To people with 1% idle consumption:
do you have dashcam or anything that is connected to your car, through USB, rain sensor wire or other powered source that is supposed to be off when the car is sleeping?
do you have dashcam
I do. I'm currently shopping for a logging USB-C multimeter, and a logging ODB2 plug to track activity over time (self powered if possible)
I did check my ODB2 yesterday, and on startup, there's 24 amps going into my 12v battery, and the DC-DC converter is reporting 57 amps of current. So the 12v is certainly a load when waking up to charge it back up. A logger would allow me to see activity over time when the car is entire 'turned off'.
I shall also reduce the dashcam's parking mode time.
One note, my dashcam takes a mile or 2 to get going when I drive away in the morning, which indicates the 12v is quite low.
Previously, I've lost 1%/day a few times.
Last week, I reconfigured my Dashcam parking mode to turn off much sooner than the 24 hours I had previously (with the hardwire also turning off based on voltage), and I also set it to a low frame rate instead of lower quality.
Today, after 3 days of sitting idle over the weekend, I'd lost zero % SOC when getting back in and driving.
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
Some people are having discharge when sitting idle issue, some are happy to report no discharge. Since I do have this problem, I want to gather some stats before talking to the dealer. Maybe I will find a solution which I'm happy to share here.
My 12 V battery draw is higher than on maybe someone else's car who does not have a dashcam. if the 12V is less used the car should also less likely take too much if any to charge the 12V ...so the SoC loss is less as well. Mine is 1% SoC loss per day as my 12V battery is drained constantly.
EVowner
Macan 4s
No dashcam or any additional accessory on mine.
After last charge to 80% which ended again with being 77% when I got to the car few hours later I am getting range 261km at 10C outside without even putting anything to nav... At that temp car thinks now that to cover 120km on highway (2/3 at 130km/h 1/3 110km/h) it needs 44% of battery.
M324
Martin
Germany
Porsche Macan electric 4S
Still same issue for me. Not possible to charge to 80% anymore. This time it ended up at 76% even though the app told me it reached 80% 8 hours ago. I also experienced a huge drop in range even though my overall consumption actually decreased. At 50% of charge it shows me around 120 km of range which would be 240 km at 100%. Way less then one year ago when at this time of the year I had 350-400 km of range at 100%.
dimaa_6abc
Kyiv, Ukraine
Macan EV 4S
Strange thing happened. My Macan 4S used to have almost all the issues reported here - inability to reach target SoC while AC-charging, 1-1.5% of SoC loss per day while sitting idle, uneven SoC decrease while driving, SoC going up or down after resting for 2-3 hours after the drive. But recently it stopped losing SoC while parked. I charged it on Jan 26th and we did not drive it until yesterday, Feb 4th. It is 8.5 days of being completely idle in our garage. Zero SoC loss, yesterday it showed 80%.
platypus
New York
'24 Macan Turbo Electric
Did you get a recent software update? I assume you didn’t.
I’m getting my car back tomorrow after it spent 3 weeks at the dealership (for this + the slow DC charging issue). They could replicate the battery drain, sent the data to Porsche, and after careful consideration… they’ve decided to continue arguing this is normal.
At this point I’m going to move on and try to enjoy the car, hoping they soon address it in a software update.
Do you have a dash cam or anything connected to the car?
platypus
New York
Yes, but they disconnected it when they tested. That said, it doesn’t hurt to try disconnecting everything again on my own.
Yes, you should try. To me, the car when idling, is able to wake several times a day. I suspect because of the dashcam, the car takes longer to go in sleep mode...
to me, it's a new behavior of the car due to to some firmware updates: for the whole 10 months of ownership, when idling, my fitcamx wired on the sensor rain never recorded when idling, and now, it does several times...
'in my case, that seems to explain the idling consumption
dimaa_6abc
Kyiv, Ukraine
Macan EV 4S
I had it in early November 2025, not sure if it passes for "recent". After that, service representative reported 1% of drain for 3 days. But they are arguing even 1% per day is normal, from which I draw a conclusion that to be happy, one needs to either enjoy the car or get rid of it.
platypus
New York
Yes, you should try. To me, the car when idling, is able to wake several times a day. I suspect because of the dashcam, the car takes longer to go in sleep mode…
I did suspect this as well, and told them to test exactly that. But I’ll try on my own. How do you know it takes longer to enter sleep mode?
platypus
New York
Agreed! I did bring it again because of the slow DC charging issue, but I’m thinking I should have tried to troubleshoot both issues myself, since I don’t think anything has changed after their intervention. At least now I have the latest updates.
