- First Name
- Gregory
- Sep 3, 2024
- Belgium
- Boxster 718, Macan 4 (coming), X5 45e
Hi
I've got a macan 4 for about 1 year now
I know the software part can be a bit fuzzy (key changing its user profile, etc, false alerts, etc.)
But this time it's really weird
I've the "air suspension" trim.
I use it quite often, changing manually the car level from up, normal, low, lowest, depending on the road condition & speed
I also use the memory function, so that it goes up always at the same location
And now, since 3 days,
1/ the menu disappeared from the car > drive menu (I still have "chassis", so I can switch between normal, sport & sport +)
2/ the shortcut I had on the 3 column dashboard also not showing (quite logic I think)
3/ screen behind the steering wheel : it normally shows when the car is "up" due to location memory => no display either
I'm going to the dealer for other stuff (replacing the LIDAR I suspect : no vehicule detection in front, no cruise control anymore)
I will ask software upgrade as well
l'll keep updating this post with the outcome
