robrain
Rob
Whistler, BC, Canada
Am I the only one not loving the bubble eyes?
It's still masked in the video (and the others on YouTube that came out in the last couple of days). Almost all of the "headlights" are transfers, even over the actual glass portions. And I think the horizontal lines below it are also disguises. When it's finally unmasked I suspect it will look very Macan-like. The Porsche app has a somewhat less-disguised version with essentially the Macan driving lights (September 15, Discover section), albeit with more distracting stickers on the rest of the front..
FirstEV
Sweden
Pretty insane average of about 560km with off-road package (removes about 30km range when added to it) including roads with obstacles with 3 people in the car. Impressive to say the least.
beez
B
Ah. Thank you!
Not really if you factor in the large battery - 113kWh (107.8 usable).
FirstEV
Sweden
Depends on how you see it. I think Rivian has about 140kW battery for the same range.. so it depends!
It is pretty comparable to the iX in terms of battery size. Haven’t watched the video but if this is a real test to empty it’s pretty good. It isn’t hard to get an iX50 with aero wheels to report 330-350 miles range in day to day but another thing to actually get it at freeway speed.
poul
Poul
Denmark
Porsche Macan ev RWD
I am new to the forum and on variation in Germany at the moment. Byt i get 490 km range in my macan rwd at 130-140 kph with 4 people in the car. I am more than satisfied. (20" with michelin crossclimate)
de0xyrib0se
Chris
Sofia, Bulgaria
It has a good range but there is no way you are pulling 19.8kWh/100km @ 140km/h unless you are going downhill or mixing this with city driving :)
To measure consumption at those speeds make sure your panel is set to 'Since last charge'. Stop on a charging station on the highway, charge it up. Leave and gun it to 140km/h immediately. If you get numbers lower than 24kWh/100km average on the autobahn I'd say its a miracle.
It’s an RWD on 20 inch … now that said average speed is important, if you drive 100km at 130-140 and the rest is more like 100 your average is probably 110 and that should be perfectly possible on a good day …
Anyone know if you can have it configured at Porsche? Curious if it is already orderable.
