- First Name
- David
- Jan 28, 2019
- Santa Cruz
- Macan Turbo,Cayenne Hybrid, 911(s) GT3/Convertable
well team - after a fairly blissful 12,792 miles and two major road trips (Road Trip 1, Road Trip 2) in less than a year it's come time to bring the 2024 Macan Turbo EV in for it's first service since being picked up from PECATL in Nov. of 2024 - nothing major but a couple of warranty issues and pending recalls made me do it…
I had this service "scheduled" as an appointment so a Loaner was requested and provided!!! Bonus - Macan 4 EV Loaner!!!!
My impressions of loaner are:
- well equipped - all options checked - minus: Full leather, headliner, sun visors
- loaner has: massage, passenger display, hud, power charge port doors, air suspension, etc
- I can't tell if it has RWS or not
- but when this gets cycled on to the used market it will be "nicely equipped"
- Macan 4 - acceleration is muted but ample - it's not my Turbo - but it only seems to suffer "off the line" - once you're at speed the car is responsive and down right quick - this surprised me - the 4 is plenty quick and vs. most ICE SUV's nearly high performance
- it's early days on the loaner - but my impression is the 22" wheels make the ride a bit more bouncy vs. my Turbo w/20" wheels - but it's still really good
- could be tire pressure - PSI is pretty high all around on all 4 tires - do I dare mess with tire pressure on a loaner?
- Gentian blue is still one of my favorite colors - looks so good on this car
- Loaner has the wheels I simply could not bring myself to pay for - I really like them and their look on this car - 22" Exclusive Design Wheels (Silver) $4920
- I wanted to option the CF version of these wheels $8,960 - I decided nearly $10k for wheels was excessive and 22" ride quality and range hit was a reasonable compromise - but I still love their look and they are undeniably the best wheels in terms of appearance
- personally I would miss the "full leather" - there are bits of interior trim that are simply medium grade plastic on the loaner
- headliner is fine but lacks the upgraded feel of the headliner in my Turbo
- the plastic sun visors just feel cheap on a car at this price point
- my experience with the 4's "power performance" has surprised me in a pleasant way - but confirms my assertion that for me personally the 4S (or a future GTS) Macan EV has simply got to be the "sweet spot" - while the 4 will do it for most people - I've got to believe the 4S (or a potential GTS) would be the best spot in the line up…
- CUSTOMER STATES THAT THE COMFORT ACCESS IS NO LONGER WORKING ON THE DRIVER SIDE. WILL NOT AUTO UNLOCK, LOCK ETC..PLEASE INSPECT AND REPORT
- CUSTOMER STATES THAT THERE WAS A chassis error - ride level adjustment WAS disabled FOR FOUR DAYS STRAIGHT. PLEASE INSPECTAND REPORT
- ARC5 recall campaign Re-coding main control unit for body electronics (HCP4)and control unit for headlights Re-code main control unit for body electronics (HCP4). For vehicles with country-specific equipment C36 Canada, the control units for headlights (MX14, MX15) and the control units for auxiliary headlights (MX1, sMX2) must also be re-coded. Information The minimum programming requirement is PIWIS Tester software release 43.000.040 (or higher). Information The prerequisite for this action is the successful implementation of the campaign WRM0 Update to software network VR28.11. If software network 28.11 has not yet been installed on the respective vehicle, this must be done before carrying out the present action here. SCOPE 1 74TU, SCOPE 2 74TU
- ASA3 Re-Program Reversing Camera Control Unit and, if necessary, Replace Reversing Camera and Surround View Cameras (Recall Campaign) In rare cases, the reversing camera of the affected vehicles cannot be activated when ParkAssist is switched on due to a software error. In addition, with a very small number of affected vehicles, it is possible that the housing of the reversing camera and individual surround view cameras in the surround view equipment option were not bonded as per default value specifications. As a result, no camera image is displayed in the central display when ParkAssist is activated contrary to the default value specifications. If the camera housing is not bonded correctly, moisture can penetrate and impair the camera image. Action: Reprogram reversing camera control unit using the PIWIS Tester and replace reversing camera and individual surround view cameras if necessary. Each vehicle was assigned exactly to one scope that includes the actions required for each vehicle. PIWIS Tester software release 43.300.040 (or higher) SCOPE 1-127TU, 2-25TU, 3-230TU, 4-556TU, 5-271TU, 6-271TU, 7-597TU, 8-597TU, 9-312TU, 10-639TU
- WSD0 - Install Upgrade to the Software Network VR28.11 (Workshop Campaign) Additional software optimizations are available for various control units for the Macan Electric. An overview of the changes that will be implemented with the software update can be found in the appendix under ? Technical Information 'Overview of software update changes'. Action: Perform reprogramming of the affected vehicle using the PIWIS Tester on the incremented software network VR28.11. Information The minimum programming requirement is the PIWIS Tester software release 43.300.010 (or higher). Information The prerequisite for this action is the successful implementation of the campaign WRM0 Update to software network VR28.11. If software network 28.11 has not yet been installed on the respective vehicle, this must be done before carrying out the present action here. Read TI WRM0 for details on this. SCOPE 1 147TU
