App remote heating work in your Porsche Macan Electric
gunnar
gunnar
sweden
Porsche Macan 4 2025
How does the remote heating work in your Porsche Macan Electric?
In my Macan 4 Electric (2024) I cannot control the seat heating from the My Porsche app on my iPhone. It’s not possible to turn on the seat heater from the app.
Another issue is that when we have had the seat heaters on, leave the car, and return later, the seat heater on the driver’s seat is on, but not on the passenger seat—even if it had also been on before.
Is anyone else experiencing this problem?
gunnar
gunnar
sweden
It works for me, both cabin heating and cooling. I don’t know how the passenger seat behaves because I typically drive by myself.
Have you had any updates done on the car, such as the WSJ0 / V28.13 campaign?
Ok but what about the seat heater, is it possible for you to check it, if you have some winter climate:)
MMR
I haven’t preconditioned in a month or so
But I’m pretty sure toggling next to the seat turns the seat heating on/off
Electric Macan EV App remote heating work in your Porsche Macan Electric IMG_5903
rcomeau
Roch
Montreal, Canada
2019 Jaguar I-Pace
I think seat heaters don't work well unless someone is sitting in it (the seat is mostly foam insulation, so little thermal mass and the leather is not a great heat conductor), so maybe they don't turn on because the wont do much until you sit in it. Just a guess.
Sorry if I wasn't clear -- the seat heating worked at least for the driver seat provided it is selected in the app. I haven’t tried the passenger seat heating because it’s typically empty.
gunnar
gunnar
sweden
Test it's not that easy to see if it works. I suspect Porsche thought completely wrong when they programmed this. The fact that the passenger seat doesn't start is also completely crazy. Should the passenger sit with a cold seat in a premium car?
Jan_Macan4S
Juan Carlos
Madrid - ES
Macan 4S, BMW M235i, BMW X4,
Regardless is empty or not you can heat / cool every seat from the app
Electric Macan EV App remote heating work in your Porsche Macan Electric IMG_9370
Stuart
Stuart
Amsterdam
No issues works like a charm, as has been stated select the zones to be heated and should all work. Always nice and toasty on cold mornings both driver and passenger side.
gunnar
gunnar
sweden
Do you have ventilation in your seats? I do not have it. Porsche support can’t explain it.
gunnar
gunnar
sweden
Thanks, do you have ventilation in your seats?
Stuart
Stuart
Amsterdam
Yes we have the cooling option, not sure if the cooling function works with the preconditioning yet as not had the car a month yet, and weather is still quite cool here in NL :)
Stuart
Stuart
Amsterdam
Did you option it?? as if you did and its not there then suggest checking your original order and contcting the dealer
gunnar
gunnar
sweden
Hi, no, I have not chosen the ventilated seats option, I only have heated seats.
gunnar
gunnar
sweden
This my last conversation with Porsche support today, they don't know how it works. I will come back.
Dear Mr. Johannesson,
thank you for your patience.
Following your message, I have forwarded the details to our technical team for review. In order for them to accurately analyse the situation, they have kindly requested that you perform the following test on the vehicle’s seat heating functions:
  1. Activate all seat heating functions and set them to the highest mode.
  2. Within the climatization settings of the My Porsche App (MPA), ensure that all seat heating options are selected.
  3. Prior to departure, activate the climatization command.
  4. Carefully verify that all seat heaters are switching on and that the seats are warming up as expected.
  5. Completing this procedure will provide the technical team with crucial information to assess the performance and functionality of the seat heating system.
