New EV 4S picked up yesterday - questions re POI and Frunk
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
I picked up my new 4S yesterday and have a couple of questions that I hope someone can help with…
  1. how do I add POIs to navigation (e.g. UK speed cameras)?
  2. my Frunk doesnt open with the ‘hand swipe’. is this an option, config setting or do I have a fault(y hand)?
Thanks in advance..
bbmertz
That is a configuration option under Vehicle Settings > Lock that you have to turn on to enable frunk swipe opening as well as trunk foot gesture opening.
thealbs
thealbs
Manchester, UK
Thanks but it doesnt show on my menu here. I know the trunk foot gesture is an option here (UK) which I didn't select, but thought the Frunk hand-wave was standard. It appears maybe not., Not a major issue as I can press the key but a neat trick to show-off with…
EDIT: I’ve done a little more digging and it appears to be part of the Comfort Access option.
If anyone knows how to add those POIs to the Navigation system that would be really helpful still.
you didn't add the comfort access package?
thealbs
thealbs
Manchester, UK
No - gotta draw the line somewhere on that options list and didnt fancy the keyless entry enough. I can manage without the frunk/trunk but was just a little confused as I thought the Frunk opening was standard. Not the end of the world ;-)
I did the same. No comfort access, and that was more because in the last comfort access car I had, I always used a Faraday pouch to block the signal for would be hackers.
But Faraday pouch defeats the purpose of comfort access, ie take the Faraday pouch out of the pocket, take the key out from the pouch for comfort access to work.
That was a bit more effort than just pressing a button on the key fob ;)
Thanks in advance..
You can't add POIs such as cameras to NAV.
Foot gesture comes with Comfort Access as the others have said.
It may.become available as an FOD (function on demand) feature as it was in the Taycan. Slightly less functionality (no lock button on the hatch) if not factory optioned. .
thealbs
thealbs
Manchester, UK
Ah - that's a shame. Was hoping to take this opportunity to flip from Apple Maps to the built-in Nav system but this is quite an important function for me. It seems it was possible in previous versions of the PCM but not now.
It is strange that the map view allows you to select what you want to see and POIs is one of the options, alongside other common locations, so hopefully the is a thing for the future. Thanks for clarifying
jm1883
James
Manchester, UK
I’m using CarPlay and Apple Maps for the same reason. If the speed camera alerts were in the PCM Nav then I’d make the switch PCM completely, as the Spotify app is very good.
I've had many Porsches over the years and POI has always featured but no way to add your own.
POI is simply a pre-configured list to display all or a subset.
PCM across the range will get a major overhaul as it switches to native Android Auto for all functions which may open the door to personalised POIs. Don't expect a retrofit for legacy PCMs.
SuperH
Helen
Walsall, West Midlands
I have comfort access and after the initial showing off of the magical wave to friends (which is still a bit temperamental anyway) - trust me that it looses its appeal lol You have to manually close the frunk, which involves pushing the bonnet down onto the locking mechanism and potentially getting dirty hands (first world issues I know) so I've found that I've abandoned using it mostly, in preference for the boot.
Regarding Apple Maps, at least on the Macan Carplay integrates with the drivers screen, and not just the central display, so you can see the route map directly in front of you rather than keep having to look sideways.
daercl
Reigate , United Kingdom
Macan 4S EV
Hi , I’m using Waze and with Apple car it show the cameras and everything as I have on Waze
I am glad that I don’t have comfort access as there are hackers all over to catch your code and …..
raybey
Ray
Suffolk, UK
Macan EV 4S
Is the spotify app using data from the data pass or from your connected phone. My data pass still hasn't been sorted after multiple email to and from internetinthecar.vodaphone
Out of interest why are you purchasing a data package outwith the one which comes with the car?
raybey
Ray
Suffolk, UK
Macan EV 4S
I haven't purchased a separate data pass. Its the one that came with the car which is having problems working. The Porsche app and the data pass account say it should all be connected and working but car says no
