Interior ventilation /AC fan noisy
castlg
Gary
Westhampton
2025 Macan EV 4S
Does anyone else find the interior ventilation fan, whether on A/C or not, noisy even at the lowest speed setting? Any thoughts would be welcome.
Not at all. The seat ventilation is a bit loud on max.
Do you have auto turned on? Now that I think about it, the fan was a bit loud when my father in law tried adjusting the hvac manually even with a low fan. I think he had it on a setting that was blowing into the footwell or something because it was audible but not much airflow. I turned auto back on and adjusted the temp instead of the fan and we got silent cool air back at the main dash vents
DC Mac
Pasadena, CA.
noticed the same thing. On auto it’s quieter as all the dash vents get used, less noise and more cooling results.
Ben4S
Ben
Spain
Macan GTS 2017, 4S in April
Turning off the fans in the back if nobody is sitting there also helps reduce the noise. I found that the fans in the front get louder if the ventilation in the back is on.
The fans in the front were extremly loudy until I realized it was because my daughters moved the temp at the back to the lowest and fan speed high.
fubar.droid
Yes when the fan is on the higher side, it's very noisy and annoying.
castlg
castlg
Gary
Westhampton
2025 Macan EV 4S
I will try that tomorrow. Thanks for the info
