Icons overlapping make it hard / impossible to select or move back
JonnyDW
Jonathan
Hampshire, UK
A little hard to see from this picture, but the selection buttons for the locking options were overlapping the persistent menu bar on the right hand side so that you couldn't choose to go back! Had to do a soft reset on the PCM by holding the mute button. Is there another way? Have others had this?
Electric Macan EV Icons overlapping make it hard / impossible to select or move back IMG_0323
That looks like a flipped-layout bug! Your flag says US though, so why is the menu bar on the right?
Can you swipe right from the left edge of the screen (or swipe left from the right edge) to back out?
JonnyDW
JonnyDW
Jonathan
Hampshire, UK
Odd! I’m in UK, need to change my flag. So is there a known bug for right hand drive? I didn’t try swiping - does that generally work? I’ll give it a go if / when it happens again.
MMR
Electric Macan EV Icons overlapping make it hard / impossible to select or move back IMG_6338
I have the same issue but only on the Drive screen and only sometimes.
When it happens I can select the Drive screen options but not the sidebar icons.
I’m assuming it’s an MY26 quirk.
pm4s
Yeah it's 1 of the only 2 things being worse on the new model I could find, the other being the missing power split/regen animation under Trip.
Stuart
Stuart
Amsterdam
push and hold the volume button that will reset the PCM
