Macan GTS EV in UK not compatible with Octopus intelligent go. How do I set a charge timer in the car?
ianDB
Ian
uk
maxan ev gts, bmw ix
Picked up the Macan GTS on Friday and can’t add it to the Octopus account as a replacement for my BMW iX (says it’s not compatible!)
I’ve found out how to set a ‘charge by’ timer in the car but can’t work out of if I can set a ‘start charging’ timer so it starts when the cheap rate electricity kicks in.
Anyone know if it’s possible?
my Rolec Zura dual charger won’t set charger periods dispite it supposed to doing so (it never has in the 2 years I’ve had the charger).
The charging concept works on a departure time only.
You can direct charge to charge straight away.
You can set a minimum charge level which will charge straight away until that levels is reached.
You can configure optimised charging to take advantage of known off peak periods.
All of the above is achievable via the PCM or My Porsche app.
Until you learn more about the Octopus set up (trawl the forum) then set your EVSE to dumb mode - disable any programming and program only via the PCM or My Porsche app.
With some research you most likely can get your Octopus arrangement configured correctly.
Meantime I encourage you to read the Owner's Manual and quickly get up to speed on the basics.
MMR
I had to make my MY26 Turbo “act dumb” so that Octopus Energy could communicate with my Andersen A3 charger and enable Intelligent Octopus Go.
It might be an MY26-specific issue, as my friend’s MY25 Turbo appears to work with Intelligent Octopus Go as expected.
Andy718S
Andy
Macan EV GTS, Boxster 718S (Macan EV 4S now sold)
Some models of the Macan EV were shown as compatible with Intelligent Octopus Go whilst some were shown as not being compatible. I raised a query with Octopus last month and they amended the initial check shown on the IOG product page to show all Macan EV models as being compatible.
However, having now taken delivery of my car, when I attempted to connect my GTS under devices, it was shown as not being compatible. A query was therefore raised with Octopus who have referred the matter to their product team. I’m hoping to hear back today.
MTGBUK
Can’t guarantee but you could try the optimised charging in the departures on the app
Electric Macan EV Macan GTS EV in UK not compatible with Octopus intelligent go. How do I set a charge timer in the car? IMG_1213
JonnyDW
Jonathan
Hampshire, UK
To set the timer from the car to charge from 11:30 - 5:30 just set a departure timer and select Optimised Charging (manual) to set the above time. Should then charge within that time period provided that is sufficient to get the car to desired percentage by the set time.
But a thought on Octopus - can you select another Macan model that is accepted by the App - I wonder if they’re actually any different and it’s just that Octopus haven’t certified the GTS yet. Might be worth a try.
Andy718S
Andy
I would hold fire for a couple of days. As I mentioned above, the GTS has been referred to the Octopus product team to look at adding the model. They normally reply within a couple of days.
Setting up a manual charge as mentioned above will not fulfil the IOG T&C's which specify the need for one smart charge per month. Ideally, the GTS will be added to the list of compatible cars but if not, then would be the time to look at instead adding the car as another Macan variant.
ianDB
ianDB
Ian
uk
Excellent. Can you report back when you have a reply please
That’s a great idea. Thanks.
Andy718S
Andy
Yes, I’ll update this thread as soon as Octopus respond.
QuiteBig
Steve
Macan electric 4S, BMW 440i, Mini Cooper electric, Fiat 500
I had that issue on my 4S when I first tried to connect up in April. I just used the alternative, which is to let Octopus decide when to charge and have the car set to charge whenever it can. I has worked very well and I have never wanted to change the car to be the boss. I can usually get 70Kw or more in if I plug in at lunchtime-ish by the next morning as even in winter, it will charge at odd times way before the official 2330 start. See the attached picture for all the charging i got done back in January.
Electric Macan EV Macan GTS EV in UK not compatible with Octopus intelligent go. How do I set a charge timer in the car? IMG_3836
Electric Macan EV Macan GTS EV in UK not compatible with Octopus intelligent go. How do I set a charge timer in the car? IMG_3835
QuiteBig
Steve
just to add that I have just plugged in on 25% and told Octopus I want it charged by tomorrow 11am (the latest you can set). I said 11am so i get the best chance of filling to 100%. You will see I am already getting a short charge, and that has changed since I originally plugged in about 30 mins ago. All of this is at 7p.
On sunny days in the summer I have known to be fully charged by midnight.
Electric Macan EV Macan GTS EV in UK not compatible with Octopus intelligent go. How do I set a charge timer in the car? IMG_9167
Marvellous.
Note - don't charge to 100% unless you plan to use most of that charge on the day (80% is a better target and prolongs battery life). EV charging is based on charge what you need to use for that day with a bit in reserve (min 25%) and so dailying charging isn't typically needed.
QuiteBig
Steve
Marvellous.
Thanks, but I don’t need advice on how much to charge. Not sure why you thought that was daily? I have not charged to 100% since 10th January and typically leave it at around 50%. I am driving 500 miles from Friday over the weekend so wanted a full charge to start.
It wasn't clear and I never mentioned daily either but in general the advice is correct. Leaving the car standing with a full battery for several days is not recommended. Your post read as if you were aiming to charge to 100% now that you have Octopus configured.
You should comfortably get to 100% on Friday from an SOC of 30% commencing Thursday but I guess you already know that too.
