BigApple
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
I ran a cable from the usbc port at the center Console a long up towards the outside of the seat. The wiring is done in a way so it is non destructive. In case of warranty reasons. The iPads are on magnets. So they can easily be removed or turned into portrait mode.
Alex74
Alex
Macan Turbo, 356,911, …
Can you show how you installed this?
BigApple
BigApple
Andreas
NJ
Glued a magnet to the seat. Added a metal plate on the iPad side to create the bond. The cable holder is there to hold the cable in case I unplug the iPad from it
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1349
I ran the wire up on the side of the chair. Trying to avoid holes/drilling for warranty reasons. This way I can return it easily to factory look if needed.
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1348
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1344
Below I added magnetic usbc plugs to avoid breaking in case they get hit by feet (likely! knowing my kids)
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1350
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1351
Vosmans
Thierry
Brussels
Macan EV 4S
Hi - great !! Do you have Amazon links to the components you used ?
pm4s
That is the coolest mod I have ever seen (apart from the glue part 😁 )
The only thing I can't figure out is how those cables stay so perfectly tucked-in the seat back recess, is it only for the photo?
I would imagine in a couple of minutes they would be dangling all over?
BigApple
BigApple
Andreas
NJ
Link to the clear tape I used. I hope the link works.
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1355
the cable and links vary from the plugs needed for the iPad that is used. I needed lightning plugs for my older 2 iPad airs. Here is the bottom portion
Electric Macan EV Back seat entertainment upgrade: 2 iPads on seat backs IMG_1356
I picked a cable that is not fully black. More grayish. It had to be lightning on one side for me. If you need USB’c you can get plenty on Amazon. I think as I needed lightning and 180 degree I think I got those from Ali express. I will post if I find the link to the order. It’s a while back.
Alex74
Alex
Thank you 🙏
on the taycan it was possible for the option for the ipads, now it Is not.
looks a great solution
mbocmrkb
Macan 4s
Bravo. Impressive. I will hope to try this for my kids at some point, if there is a reliable glue free version of this installation..
Or rather, what's your contingency for the for glue should you require to restore this to factory look?
henrus
Henry
Bay Area
You are a legend :rock:
BigApple
BigApple
Andreas
NJ
Actually both of them came off because I did not wait 72h for the glue (tape) to complete. And on one of them I even added glue enhancer. And on both I was able to take the glue of just fine without it leaving marks. (Goo be gone) is your friend for such situation.
