Iceman153
Mark
Vancouver, BC
Macan Turbo Electric, Land Rover Defender.
I just got around to installing the fitcamx into my macan ev using the porsche factory dashcam prewire connection. While I was researching for this I didn't see a proper write up for the macan ev, the post about the '25 cayenne on rennlist was useful, while also misleading. Having specifics for our car would have helped a lot, so figured I'd take a few photos along the way. Took me about 4 hours all up, but I feel like doing it again with these instructions you could probably half that.
When ordering the fitcamx, get the model A, they will reach out to confirm your vehicle model, and when they did this I decided to ask if they had an adapter for the prewire connection. I sent them a picture of the connector, and they threw one in the box with my fitcamx free of charge. I don't know why they don't advertise this on their listing page, but having that adapter really simplifies things. It gives you parking mode without having to bother tapping into fuses, or worry about the piggy back adapter causing issues with your wiper sensor. As it's leveraging the factory dashcam connection I don't see how warranty could have any issues with it.
What you'll need:
- FitCAMX (I got the 4k with rear camera)
- Dashcam prewire adapter from fitcamx
- A good set of pry tools (https://www.amazon.ca/dp/B09BB8VFLY?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1)
- wire pull tool (comes in the pry tool kit above)
- automotive cloth tape and some foam.
Install :
1 - Start by removing the forward part of the overhead console trim. Get two solid wide pry tools at the two green arrows and push towards the windscreen. You can do one side first, I think that is how it went for me. Needs quite a bit of force, be careful not to scratch/mark the trim.
Electric Macan EV FitCAMX Dashcam Install 1
This is the inside of that trim peice for reference on where the clips are. red are the clips, green is a sort of silicone/rubber guide, and yellow is a tether that holds the trim to the car in an accident :
Electric Macan EV FitCAMX Dashcam Install 2
2- Lower the main overhead console. This is where that cayenne thread has bad information, do not start trying to pry it off, the outer trim can be removed, but you don't want to do that. the part labeled (1.) in the photo below is actually a spring loaded switch that pushes inward, it disengages the two tabs (2.). Just grab the larger metal pry tool from the set above, insert the flat end in the direction of the arrow and push the switch in. it does not need much force and disengages very easily when pushed correctly. The unit then swings down on a hinge and exposes the pre-wire connectors.
Electric Macan EV FitCAMX Dashcam Install 3
Electric Macan EV FitCAMX Dashcam Install 4
3- Next remove the rear view mirror (you could do this before the console if desired). First step is to remove the inner windscreen trim (not the part the fitcamx replaces, that is the outer trim.). to do this pry the top corners of the outer trim outward to release the tabs on the inner trim, then give it a firm pull downward and it should be off. It is tethered to the car, just leave it dangling.
Electric Macan EV FitCAMX Dashcam Install 5
Electric Macan EV FitCAMX Dashcam Install 6
Electric Macan EV FitCAMX Dashcam Install 7
4- Remove the rear view mirror itself from the car. DO NOT try to remove the outer trim, I couldn't figure out why, but it is very difficult to remove with the mirror on the car. I wasted a lot of time trying to get it off, was surprised I didn't break it honestly. After removing the mirror it comes off easily. Just grab the base of the mirror itself, and rotate it counter clockwise (lefty loosey), it'll move maybe a 1/4 turn and can then be pulled down. it has a tether and will dangled from it no problem. Below is it dangling with the two lines being where I routed the FitCAMX's two wires. The red line is where I routed the main dashcam wire, and the green line is where I ran the rear camera wire. There is a very tempting looking hole for the rear view mirror wiring connector, but there just wasn't quite enough room to fit either of the fitcamx connectors through it. after deciding on the route for the wires pop the fitcamx onto the mirror, then put the mirror back on the car. Pretty straight forward, i hooked the bottom two prongs on first, pushed the top flush, then rotated right/clockwise until it clicked back in place.
Electric Macan EV FitCAMX Dashcam Install 8
5- Connect the fitcamx -> porsche prewire adapter, and feed it and the rear camera connector through to the main overhead console. There is plenty of room, and the adapter is the perfect length. highlighted the pre-wire connector in the car in red, the fitcamx adapter clicks in very easily. the green highlight is the rear camera FAKRA connector, we won't need to use this.
Electric Macan EV FitCAMX Dashcam Install 9
6- Install the dashcam fuses as per the official porsche prewire instructions here : https://static.nhtsa.gov/odi/tsbs/2024/MC-11011672-0001.pdf. the 5A fuse box is located in the passenger footwell, very easy to access, i circled where the fuse goes. the 10A fuse goes in the fusebox in the frunk, remove the cover that is circled, it goes in slot 1 which is labeled, and there is a diagram of it's location in the instructions.
Electric Macan EV FitCAMX Dashcam Install 10
Electric Macan EV FitCAMX Dashcam Install 11
6- Run the rear camera wire along the passenger side of the car along the edge of the headliner. it tucks under the roof lining quite easily the whole way along. the B Pillar is a little fiddley, but quite straight forward. Given the rear pre-wire location on the side of the luggage compartment, there is no point to try and leverage it, it's faster to simply run the fitcamx wire. The only complication is getting it through the trunk door wiring channel. You'll need to pry off the rubber cover from the plastic base that is clipped into the frame of the car, do this for both ends of the channel. note to put these back after you pull the wire through you'll need to unclip the plastic base from the car, then pull the rubber channel back over the edges of the base, and finally clip the re-assembled part back into the car.
Now you'll need the wire pull here that's in the kit. with a pry tool you should be able to create enough gap to feed the wire pull up into the hole, then pull the camera wire through. no need to actually lower the headliner here like in the instructions. do the same trick to pull the wire through the rubber channel as it's pretty tight. Then you'll need to remove only the top trim from the hatch. photo shows the path of the wire in red, and the green dashes are where the clips are on the top trim. note that each corner has a sort of plastic hook/lip that wraps around the trim peices next to them. you'll need to bend the corners outward to disengage the hooks before starting to pull. clips on the sides are plastic, clips in the middle are metal.
Electric Macan EV FitCAMX Dashcam Install 12
That's about it, after you choose a spot to place it, just bundle up the excess wire and pop it behind that top trim with some foam/cloth tape to stop rattles. I chose to install the rear camera here as it's as high as it can be while being completely hidden behind the rear headrest. The rear visibility is already bad enough in the macan, didn't want to compromise that. Do note as the glass is curved here, the camera will be at a slight angle and not quite centered, but it does the job. I was more worried about the looks/position of it not annoying me than the video quality.
Update: realized you can mount the camera on the top plastic trim itself (yellow square), up against the glass, and it is almost completely hidden in the rear view. Drivers side hides it a little better. This also means you don't risk damage to the defrost wires if it ever needs removed.
Finished product below :
Electric Macan EV FitCAMX Dashcam Install 13
Electric Macan EV FitCAMX Dashcam Install 14
Electric Macan EV FitCAMX Dashcam Install 15
someTimesJoe
Joseph
Tri Valley, Ca
Taycan CT 4S, Macan EV 4S
Very nice write up!
Would have gone this route for the clean install and if I had the prewire option for the parking mode.
Iceman153
Mark
Vancouver, BC
Very nice write up!
Thanks! Given how easy to was to run the rear camera wire, It should be just as simple to run the fuse tap wire fitcamx sells to the passenger footwell fuse box. you could leverage the same 5A fuse for BATT as the prewire, and would just need to identify an ACC source. Worst case the rear view mirror adapter they include would get you ACC.
someTimesJoe
Joseph
Tri Valley, Ca
I went with the Blackvue 2 channel so routing the rear is super easy. It sits up high in the middle and isn’t visible from the rear view mirror. My only gripes are that the front camera is big so it’s not very discreet and the power situation, I never figured out a year ago. Ended up going with the OBDC power adapter which works great for parking mode. No errors or alerts from the car but the Blackvue does alert me of low voltage drop below 11.8V from time to time if I don’t drive the vehicle for a day.
How’s the video quality front and rear?
Iceman153
Mark
Vancouver, BC
The blackvue is better as a dashcam no question, I just wanted something discreet that works. Personally I'm amazed porsche hasn't come up with a built in solution that just uses the cars cameras like tesla, it's such low hanging fruit. Android automotive I think even has built in dashcam functions, it just needs the video signals.
Anyway, are you saying that if you put the rear camera up high enough it's not visible in the rear view at all? I assumed this wasn't possible :facepalm:. I think there was a spare 3M adhesive in the box, might have to move it if that is the case.
As for quality it seems good viewed on my phone, but I haven't looked closely on a larger screen, or looked at any night footage yet. Will have to take a look later in the week.
someTimesJoe
Joseph
Tri Valley, Ca
Looked again and it’s half seen. Compared to my Taycan that is using the DR970X Box, the front camera is small but the rear is huge and it’s fully visible in my rear view.
The Macan is the regular DR970X and the rear is smaller. It’s a few centimeters below the dot matrix but this is what it looks like looking back.
Electric Macan EV FitCAMX Dashcam Install IMG_4744
Degenatron
Great write-up, the best explanation I've seen of how to remove the overhead console so I may now give it a go wiring into the dashcam pre-wire socket.
I include some pics from mine to show the tailgate panel clips for removal and alternate method for pulling the wire through the grommet!
Electric Macan EV FitCAMX Dashcam Install PXL_20250201_160534012.MP
Electric Macan EV FitCAMX Dashcam Install PXL_20250201_160602542.MP
Electric Macan EV FitCAMX Dashcam Install PXL_20250201_161836560.MP
great write up.
i really want to get one of these...I'm just kinda waiting to see if they out with an updated model.... It's oddly not looking too good.
but i'll def keep this pinned for when i do
Iceman153
Mark
Vancouver, BC
Appreciate that! Looks clean, but you got me thinking. Looking back at my install photo above it looks like it could be mounted directly on the top plastic trim. Where it gets a little thicker off center, right up against the glass instead of on the glass. So back out to the garage, and it looks like that definitely works, and certainly gives a better viewing angle for the camera. you can just barely see it when looking back :
Electric Macan EV FitCAMX Dashcam Install 1774368933012-k
Electric Macan EV FitCAMX Dashcam Install 12-2
someTimesJoe
Joseph
Tri Valley, Ca
Wow now you got me thinking if I should change mine. I should have spare 3M pads, too. That looks good now. Good work!
Iceman153
Mark
Vancouver, BC
great write up.
Thanks! I wouldn't hold my breath waiting on a new version. They basically have no competition in this space except for the aliexpress dashcams (which are essentially the same product). The only change they've made in 10 years has been to add 4k. I am pretty sure they are just uploading their custom firmware to hardware that is from the same supplier as the aliexpress dashcams and wrapping it in their packaging. I actually have a 4k aliexpress version in my other car (fitcamx didn't have their model out when I got the car as it was too new). That one is still going strong almost 5 years later. I should do an image quality comparison between them actually. but I will say that the fitcamx's app is better which has value.
I also wouldn't be surprised if the fitcamx's firmware could simply by loaded onto an aliexpress sourced dashcam, this is probably why they don't publish the firmware on their site...
JohnnyRoaster
Outside Boston
Great write up. I installed just the front camera and tapped into the rain sensor. The image quality is not great but better than I expected. I like how stealth it is. I did add the polarizing filter after the fact and found it helps with the glare and the reflection off the windshield.
Iceman153
Mark
Vancouver, BC
Will have to look into that filter
