Spoiler not extending
I never saw the spoiler come up,
after that the car was idle for 3 weeks, the spoiler came up when I was driving and I thought OK, it fixed itself …
But now even at 120 it does not come up …
I can raise it manually, but it does not seem to work automatically.
Is that a setting I overlooked somewhere?
now i'm wondering how i can make it manual only actually...
@Diego Hence my question it never comes up … only once I did see it come up but then the next day it stayed down even at 130km/h …
Select Sport + and it will come up at 90 km/h. Open the roof and it will come up at 90 km/h also in normal.
In normal with roof closed it comes up at 150 km/h.
This is my experience so far..
In normal it should come out at 110 and I drive 120 to 130 on the highway … never lifts …
I did not take the Chrono package no sport+ 🤦‍♂️ (only for suspension I have sport+)
That AI generated graph is terrible. The words are ok though. The German original gives a much better idea of the lines (e.g. Sport Plus in the AI version has 2 different lines for the spoiler going up! Nothing at 150km/h, despite that being important in the original graph)
Here's the original German showing 150km/h for Normal and Sport deployment to the top level.
I've measured Sport Plus at 94km/h, which is a bit higher than the original German graph implies.
https://www.macanevowners.com/forum/threads/at-what-speed-does-your-spoiler-extend.21181/post-318803
OK I definitely did not drive 150 when it came out so I will investigate what triggers it or not, I did not pay much attention to it till just last week
are you sure you're just not seeing it?
The wing comes up as low as 30mph .... but it's often NOT visible from the mirror...
I assumed here we were talking about the full extension, as it does indeed deploy half way - 'Eco' - much earlier, as the graph shows.
I can just about see the top of the spoiler when it's in the lower position, but I have to be looking for it.
I can confirm that at 150 km/h in Normal position the spoiler is full extended, in Sport+ and in every driving mode with the roof open (completely) the spoiler is fully extended at 90 km/h
Removed the "IA Translated" graph from my post. The German one is correct.
Electric Macan EV Spoiler not extending 1753906225889-8
Thanks, yes I saw the spoiler in eco mode as well but it will not do that. I will now try with the roof open to trigger it at lower speed so …
OK, so yes the speed is 150 not 110 😅 And yes if you open roof it is 90 …
