Radar Detector - Mirror Tap Install
JetBlack
X5M
Has anyone successfully done a mirror tap for a radar detector?
I’ve read the threads on the dashcam install but everyone is running to the fuse box.
I’d like to avoid running the cable through the headliner, A-pillars, door trim, etc.
Thanks in advance!
Electric Macan EV Radar Detector - Mirror Tap Install IMG_0054
I did: got a cable just a few inches long from the Uniden R8 to the power source by the mirror.
JetBlack
JetBlack
X5M
Thank you!
Looks like a clean install!
Do you recall which wire was the 12v power source and which wire was the ground? Would you be able to send a picture?
Thank you!
I do not recall, did this a while back: just used a multimeter to check voltage and then used this cable - it took just a few minutes honestly.
If no one else volunteers until then, I can try to remove the cover above the mirror to take a pic in a few days.
JetBlack
JetBlack
X5M
Appreciate any help you can provide. I just tried to take the plastic covers off and already broke two tabs so I’m going to stop there. If you can take some photos in the next few days that would be awesome.
JetBlack
JetBlack
X5M
Ok, figured out how to remove the plastic shrouds.
for anyone wondering - the black / white wire is the 12v and switched from ignition. The ground is the brown wire.
Electric Macan EV Radar Detector - Mirror Tap Install IMG_4460
mykl
michael
Urbana.IL
Hey, thanks for the picture. Made it super simple to install a Redline 360C. Got some of the plastic pry tools from Amazon and was able to readily release the console at the split. Easy again to remove the back half of the mirror mount cover. Pushed in the cable two pins and taped them in place for good measure. Reversed the procedure to put the mirror mount cover and console back up.
I also have the heated windshield, so have to mount the Redline high up in the cutout on the left side. The hinge point of the suction cup that came with it sits too far down the windshield, so I 3D-printed a small flat with ears that the original hinge bolt goes through. Velcroed the piece to the windshield, so I can remove it anytime. Good to go. Thanks again!
Electric Macan EV Radar Detector - Mirror Tap Install 3D PRINT
boscoji
boston
2026 porsche macan ev turbo
Hi all. Anyone else have success with a mirror tap? Does the power cut off to the radar once the car goes to sleep. I have a macan turbo incoming and would like a clean setup. Thanks
By "mirror tap" I assume you mean the rain sensor wiring harness that terminates right above the mirror, and that the FitCamX dashcam for example can plug straight into.
Yes, I'm using this for my dashcam. Yes, the power turns off when the car is off.
There are wiring harness plugs that fit as interposers for this connection available on eBay, but I don't have a link handy.
boscoji
boston
Anyone have details on how to access this area in the macan ev. Haven’t had success in finding much on this. Thanks
The FitCamX instruction video YouTube for the Macan EV is pretty good.
Iceman153
Mark
Vancouver, BC
Macan Turbo Electric, Land Rover Defender.
