Message not seen before: Component Protection Active
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
Electric Macan EV Message not seen before: Component Protection Active 1773428194238-89
Anyone seen this before. ? I get no more radio or music from Apple or android auto. Navigation audio still works.
Electric Macan EV Message not seen before: Component Protection Active 1773428119047-f
Have not had that warning. But, according to AI:
This warning can be quite startling, especially in a high-tech vehicle like the Macan EV, but it usually points to a "handshake" error between the car's various computers rather than a physical part failure.
What is Component Protection?
In the Porsche/VW Group ecosystem, Component Protection (CP) is an anti-theft measure. Each major electronic module (the infotainment screen, the amplifier, the instrument cluster) is digitally "married" to your car’s VIN.
If a module doesn't receive the correct VIN signal within a certain timeframe—or if the software "glitches" and forgets the VIN—it locks itself down to prevent the use of what it thinks might be stolen parts.
Potential Causes for Macan EV
Since your car is likely new, this is rarely due to a stolen part and more likely due to:
• Startup Sync Lag: The infotainment system (PCM) might be booting slower than the rest of the car, missing the initial security handshake.
• 12V Battery Dip: If the 12V system (which powers the computers) has a low charge or a momentary voltage drop, the modules can lose communication.
• Software Bug: A known issue in newer Porsche/VAG software where a "write error" in the memory causes a temporary VIN mismatch.
How to Resolve It
1. The Hard Reboot: Hold down the Volume/Power button on the center console for at least 10–15 seconds until the screen goes black and the Porsche logo reappears. This often forces a fresh "handshake" and clears the error.
2. The "Sleep" Cycle: Turn the car off, get out, lock it, and move the key far away for at least 20–30 minutes. This allows the car’s ECUs to fully shut down and reset. Many owners find the error gone upon returning.
3. Check the 12V Battery: If this happens frequently, have your dealer check the health of the 12V battery. EVs are notoriously sensitive to 12V fluctuations.
When to Visit the Dealer
If the message is permanent and a reboot doesn't fix it, you will need to visit a Porsche service center. They must use the PIWIS (Porsche Diagnostic Tool) to "re-marry" the component to your VIN online. This is a software-only fix and should be covered under your warranty.
Would you like me to help you find the specific button sequence for a deeper PCM factory reset, or perhaps check if there are any active recalls for your specific model year?
BigApple
BigApple
Andreas
NJ
yeah thank you i read that IA response also. But i figure i ask as to one may know to a Macan specific behavior. and solution.
