- Aug 17, 2025
- Kyiv, Ukraine
- Macan EV 4S
This started abruptly, but quite early in car's life - at around 6K km. Before that everything was perfect. I have a charging target of 80%, and smart wall charger which starts the charging on schedule, usually at 11PM or 12AM, so we plug it in and leave it, charging will start at night and will be completed in 4-5-6 hours depending on the initial level. Last few charges I found that it cannot reach that 80% level. When charging from 20+, it stuck at 76%, from 30+ at 78%. What is interesting - charger shows two drops in amperage, one to about 1/3 of full power for about 20 minutes, then to 2.3A (instead of 50) for exactly 3 hours. Car shows 0 kW at that time, meaning 0.5 kW goes somewhere but not into the battery. No A/C settings have been changed. Once I opened the car while in that state, it woke up and started charging to 80% at full power.
Also, it seems it cannot estimate state of charge precisely. Once right before the long trip it was left to charge from 75% to 100%, got 22 kWh and showed low 90s instead of 97%. Then it did not drop after driving 20 or 30 km, and started dropping by very slow rate (not usual 1% per 5 km it is supposed to do). Closer to 40% it started dropping rapidly, like 1-2-3 km per 1%. When plugged in, 30-70% consumed 30 kWh, not 40. And now I'm in strange city and SoC drops 1-2% each day while parked in underground garage where it is not too hot. SoC is well below 80%, low chance of cooling the battery. I already charged it to 100% using slow charger with the hope it will recalibrate itself, it reached 100% and did not lose it overnight which is already a good sign (it was a public charger so I unplugged it late in the evening), but SoC is still lost somewhere. I will come home and call the dealer, but if this is a rare scenario, I won't hope for a quick fix.
Communication module is not installed in my country, so there is no chance it will update the software or be awakened by the app.
