- First Name
- David
- Jan 28, 2019
- Santa Cruz
- Macan Turbo,Cayenne Hybrid, 911(s) GT3/Convertable
Well Team - recently I had to drive from Aptos, CA to UC Davis and back to Aptos, CA - round trip according to navigation is ~284 miles - charging around the route is good - so I was never in any risk - but I thought I would see if I could do it in a single charge…so I charged the night before to 100% at home - and set out in the morning for my errand to UC Davis…
trip included a detour to In/Out Burger in Vacaville, CA (Nut Tree mall location) - so strictly speaking with out the lunch detour the car would've gotten home with slight more battery left over…
based on my data - the Macan Turbo driven as I drove it this day in Normal Mode at 100% battery is a 313 mile EV on all season tires…
facts:
below are screen shots to document the range/consumption:
East Coast folks - once temps return to normal spring/summer - you'll be very very happy with your range
I plan to try the experiment again and not use HVAC ECO mode!!! and document the differences.
based on this trip - I'm super impressed with the Macan Turbo - and in normal metro freeway conditions 100% charge car should be an easy 270 mile vehicle and 300-320 miles if driven properly - if speeds were below 60 mph - I would estimate 340-350 miles would be possible.
there is nothing but good news in this posting, and all the data is from actual driving - no theories here!!
arrival at the charging station…
175 kW charge rate @ 150 kW charger - common for EA in North America…the Macan can "hold" a 175 kW charge rate until about 52% SOC (see photo)
the 175 kW "fever" breakes- it dipped to 174 kW (it does this a lot but bounces back to 175) - but in this case this was the beginning of the end of the 175 kW charge rate for this charging session…by 58% SOC we're doing 171/170 kW and trending downward…
80% SOC achieved @ 26 minutes vs. Porsche's published benchmark of 21 minutes for a 350 kW (270 kW) charge rate - 5 min is the "advantage" of a 270 kW charge rate vs. 150 kW charge rate…
85% at 30 minutes - and we unplug…
facts:
- google maps route: https://maps.app.goo.gl/vrU1riht7n3QS9wz6
- starting charge % - 100%
- starting time - ~ 6:00 am PST
- Temps
- morning (6 am to 9 am) - 48F - 55F along route
- afternoon (11:30 am to 4:45 pm) - 62F - 72F along route
- Tire pressures - not checked - standard factory pressures
- 20" tires (factory standard/default $0 option)
- Total distance driven: 284.7 miles
- Battery SOC left @ end of trip - 10% (27 miles indicated on dash)
- consumption 3.4 miles/kWh
- HVAC - ECOmode fro 265 miles of the trip
- EA charger in Aptos, CA - 150 kW chargers - plug&charged worked first time!
- charging session - 10% to 85% in 30 minutes - $0.00 cost
- 80% battery SOC reached at 26 minutes (5 min slower than Porsche rates @ 350 kW stations)
- given the charging taper curve - 270 kW charging is only beneficial for the initial battery SOC - and the net difference to 80% from 10% is 5 minutes - documented as part of this trip
- Macan Turbo EV will "flatline" @ 175 kW charge rate until ~52% SOC - only after 52% SOC does it dip below 175 kW - that is monster charging performance!!!
- Freeway speeds - typical SF Bay Area Traffic - sometimes faster than posted limits, sometimes slower - no particular speed management for range
- Hwys involved: Hwy 1, Hwy 17, Hwy 880, Hwy 680, Hwy 80
- Tires: All seasons - Factory tires Pirelli Scorpians
- Initial trip from Aptos, CA to UC Davis - Porsche nav estimated arrival @44% SOC - as the trip progressed I eventually achieved a 58% estimate - I arrived and parked @ 60% SOC
- Trip home - initial Porsche estimate indicated arrival @ 4% SOC - as trip progressed estimate improved to 9% SOC at arrival - I arrived at EA charging station at 10% SOC
- Pre-conditioning was used and the car "knew" it was going to fast charging station.
- Traffic was less congested than normal - I would estimate less than 15-20% of the trip was "below" posted limits - but I didn't measure precisely - my "feel" is that the Bay Area was less congested than I expected and flowed "better" than normal on this particular day
- Weather was mild, sunny, partly cloudy - one of the days that makes you want to live in California.
