TPMS pressures don't match pressure measured with gage
racerjim
Jim
Canonsburg, PA
2024 Mercedes Benz GLC300
My TPMS readings for all four tires read either 45 or 46 psi. I checked them today with a calibrated gage and three are at 48psi and one at49 psi. The door card states 48psi, so they are inflated correctly. How do i teach the TPMS that the current pressure reading is 48 or 49, rather than 45 or 46?
Thanks,.
Dunno, but how far above sea level are you?
The gauge is indicating tire pressure relative to the atmosphere where the TPMS sensor does not have an atmospheric reference so it indicates internal tire pressure. The difference will depend on atmospheric pressure which varies with weather and altitude. You can set it one day, but the next day it s going to be different.
At or near sea level the indications should be close.
MassDriver
Craig
Mecan EV
I’m not sure I would trust the sensors.
The view with the 0s and -5 is showing the change in pressure since the last observation (so 3 tires haven't changed but the passenger rear has dropped 5 PSI). It's not some kind of "broken sensor that's showing 5 PSI of vacuum".
racerjim
racerjim
Jim
Canonsburg, PA
Revisiting this. Got a TPMS warning (legitimate, tires were low), adjusted pressure to 49psi (using three different gages, all reading the same), the car measured the pressure at 47psi. My elevation (~1100ft above sea level) would only account for about 0.5psi of the difference. Is there a way to adjust the tire pressure measurements to align with my readings?
I would love to know how to reset these values. My 20", All Seasons should be at 41 psi for Partial Load - and indeed they currently are. However, 2 of them are reported as -1psi and the other 2 are reporting -3psi. (Note that the manual does not have a single tire configuration of 42psi, so these should be all reporting zero as the difference)
One of my wheels likes to sometimes show 39 instead of 41 (but then it only reports -1psi instead of the current -3psi it is currently displaying)
These difference values seem to be as magically generated as the Range display. But my actual PSI values do tend to be within 1 of my measurement tools at sea level.
Flying4Fun
The target PSI adjustment takes into account the current recorded temp inside the tire. This might be whats comming out as not logical if you were not aware that the inside tire temp drives the PSI adjustment number.
Electric Macan EV TPMS pressures don't match pressure measured with gage 20260727_005647000_iOS
Flying4Fun
Its also not clear from what you wrote, that you were aware of the full load vs partial load setting for the tires also? if not, maybe look into this setting when you select/change the installed tires.
Electric Macan EV TPMS pressures don't match pressure measured with gage 24ecaf46-34f8-434c-9526-66cb12efcea
jason4s
Australia
Yup this is correct. I asked Porsche directly if I should be following the doorcard pressures or the TPMS pressures and they suggested the latter as it's the most accurate.
Both the target pressure and current pressure shown by the TPMS account for temperature.
Sometimes you'll get weird readings like all tires showing the same PSI but one of them showing a deviation versus target pressure. This is because the target pressure reading for that particular tire has a different target based on the temps, usually driving around for a little bit calibrates it properly and the deviation goes away.
Here's my display
Electric Macan EV TPMS pressures don't match pressure measured with gage IMG_8605
Before parking, my driving was sedate enough to assume all tires are at essentially the same temperature - and they are at the same pressure too!
So, does this indicate I need to add pressure to (a) get back to 41 (Partial Load, 20" AS), or (b) to get to 42 or 44? This discussion suggests the former (a), and 42 and 44 are not listed pressures for my tires, so (b) is not a valid config.
The docs suggest the top number is 'Current Pressure', but (a) disagrees with that, hence my confusion here.
Electric Macan EV TPMS pressures don't match pressure measured with gage IMG_8604
Thanks,.
Check the tyre selection in the PCM matches what's fitted to your car.
Omegaman
Perry
Phoenix, Arizona
2025 Porsche Cayman - Style Edition
How is the tire temperature obtained? Does Porsche use special TPMS sensors that monitor tire temperature in addition to pressure? I'm guessing the tire temperature is using an algorithm based on outside ambient air temperature.
USMA81
Phoenix
Macan 4, Macan 4
What Craz8 posted is what I have noticed since taking delivery in 2024. The TPMS system is goofy: in his example, all the pressures are all the same, but two wheels indicate they need +1 psi adjustment to bring them to the “correct” pressure, and the other two need +3. So in his example if one followed the deviation recommendation and added air, both front wheels would have a different ending pressure, and both back wheels would also differ.
Maybe his tire temperatures are different, but the guidance immemorial has been to check pressures on cold tires (i.e., tires that most certainly are the same temperature). You can do that in the first moments of the first drive of your day. When I check cold tires, I still get the same, goofy deviations he did. So I just use a high quality gage and the door placard to adjust the pressures and use the TPMS pressures for low pressure warnings only.
racerjim
racerjim
Jim
Canonsburg, PA
I guess maybe it does take some driving for the system to calibrate itself. I just checked in the Porsche app and the tire pressure is bang on what I set them at. So i guess it just doesn't happen instantly after you adjust pressures.
