Backing up with a trailer
flowerman
Paul
Alexandria, VA
Macan S EV
I am pulling a light weight jet ski trailer. When trying to back the empty trailer to the jet ski, the (very low)trailer is not visible thru the back window or the side mirrors. When trying to turn it is also not in range of the camera. In order to navigate the trailer I have to shift my weight in the seat to look over my right shoulder. Or, I have to lean out of the driver's window. ANY shift of my weight while baking, even slightly, causes the car to shift into park. I'm guessing this is a safety feature to stop the car from moving when there is no one in the driver's seat. However, there is no way to back up a low trailer without shifting weight off at least one side of the seat.
Is there a way to turn off this safety feature when backing a trailer? Is there a way to decrease the sensitivity of the sensor?
You could post marker flags (removable) at the corners of the trailer that you may be able to see without shifting weight.
Hangpilot
Brian
2024 Macan 4, 2014 Cayman
Huh? I looked like an idiot yesterday backing my utility trailer at the dump. It went into park 3 or 4 times attempting to back up 30ft. 🙄
flowerman
flowerman
Paul
Alexandria, VA
Macan S EV
I have learned to lock my seat belt behind me when trying to back up my jet ski trailer.
You cannot deactivate the seat sensor.
You can try clip‑on tow mirrors (like K‑ Source, TowSmart, or “Snap & Zap”‑style) that clamp over the Macan’s factory side mirrors and extend outward so you can see along the full length of the trailer. They’re removable in seconds and don’t damage your mirrors.
Or you can try removable hitch‑area mirrors. Mount a small convex mirror right above or near the trailer hitch so you can see the ball and coupler from the driver’s seat.
I’m not sure whether installing a two channel (front and back) camera would help in this situation. Maybe the owners of a dash camera system can tell.
