Will 19-inch wheels fit over 4S EV brakes?
Budget M3
Macan 4S; several BMWs
I want to get a separate set of wheels for winter. I have a chance to purchase a set of 19-inch wheels with offsets that will fit (and provide extra clearance), but can’t find any data about the smaller wheel diameter which is smaller than the smallest stock sized 20-inch wheel. Anyone running 19-inches on their new Macan?
not sure...but this should be pretty easy to look and see. If anything already comes within a half inch of the wheel barrel, then no.
i'm very doubtful this wouldn't work...but i suggest, putting the car in highest height, and just low down and take a look.
Don't forget the bolt pattern, it is different from the ICE.
Budget M3
Budget M3
That’s why I ask here because it “looks” like they should fit, but it’s also rather close. I don’t want to waste the time going to look at the spare wheels unless they are a guaranteed fit.
Budget M3
Budget M3
Yes, I am aware of this. ICE Macan is 5x112. EV Macan is the usual Porsche 5x130 just like the Cayenne.
what looks close? where in particular?
Budget M3
Budget M3
Turns out the Barrel of the wheel is pretty close. Offset is ok so the inward face of the wheel clears the calipers just fine, but the close proximity of the barrel makes it not worth taking a chance at this time. I’ll wait until I can do an actual test fit.
