Nearside (left) front window opening itself
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
Has anyone had an issue with the passenger /left (nearside in UK) front window refusing to close?
Every time I close it, it drops again to approx 1/2 way open. I try the full auto-close and it drops. If I edge it one small step at a time, it looks promising then drops again when it reaches the close point. It is very frustrating.
It’s below zero degrees here in UK so I wonder if this is temperature-related and the seal not working properly but … surely people in more northern climates would suffer this all the time? Also, it is just this one door. I have checked the seal for any foreign items and all looks clear.
I have tried resetting the window and no luck so far with that either.
Anyone have any ideas?? The list of niggles continues …
I had something similar once with the roof that kept opening. Drove the car for a minutes and it closed perfectly. It hasn’t happened anymore.
Ranj
Ranj
Birmingham
Macan 4 EV, Macan 3.0 SD, M4
I had the same issue the other day it was -3 C and when I opened the door the window part opened and would not close. I scraped the ice and heated the car then it finally closed.
taycanstuff
Ice Grey 4S
Not had any issues -yet! - sounds like the sensor is over sensitive and as you have tried needs resetting to the closed position - the recent uk cold weather is probably not helping, but you would hope there would be tolerances for this.
Otherwise may be another visit to workshop :(
thealbs
thealbs
Manchester, UK
It seems to have settled this morning is working (hopefully). Resetting the window didnt seem to have any effect so I simply had to edge it as close to closed as I could overnight.
this will happen when the window can't reach the level it's trying to go to. it think something is blocking the window...like a finger, so it opens back up...
I had this issue with my audi when i had to replace a motor, the pulleys were too tight...But if yours worked before, then it's simply binding or software...
if this happens again, try raising the window with the door open, so it's not rubbing on the seals
thealbs
thealbs
Manchester, UK
Yep - that was my assumption too. I didnt think of resetting with the door open and will try that if it happens again. Thanks
This is a relearning sequence you can go through if the window(s) aren't closing to the correct stop position (same on Taycan and any frameless door).
thealbs
thealbs
Manchester, UK
Yep - tried that at the time and it didn't work. All has been fine since however.
taycanstuff
Ice Grey 4S
Thanks for raising this as an issue, word of warning for others too.
I opened my drivers rear passenger door to take out some items and left the vehicle. I was surprised when I came back that the rear passenger window had automatically opened even though I had locked the car.
Thankfully wasn't away too long from the vehicle, no warning and nothing on the app as it isn't working still properly.
I had to do a reset by keeping the rear passenger window in the up position for a while otherwise it bounced and opened again.
Looks like I'll be frequenting the forum for gremlins with the vehicle:(
thealbs
thealbs
Manchester, UK
Wow. That is concerning. Fortunately I spotted mine whilst in the drive outside my house. Will keep checking now whenever leaving in public for a while.
Albatros
Mercedes GLC AMG 43
[/QUOT
Had the same issue. this kind of reset helped. But never had it in any of my cars previously - scary to think it can stay opened for a night and snow storm...
taycanstuff
Ice Grey 4S
Still ongoing gremlins, car parked and off, all windows closed, I jump in the passenger side to get something from the glovebox, sitting there for maybe a few seconds hear a noise in the back - turn around and suprised to see the same rear passenger window has dropped down 😲
Had to turn on the car - and do the reset thing again.
Check your rear windows before you walk away.
I've also had what I thought was glitches on my app that the rear passenger door was open randomly - I'm wondering if it was an actual app glitch or indeed was my window randomly opening by itself in the carpark and then closing itself again?
thealbs
thealbs
Manchester, UK
hmmm… just had my nearside/passenger front window open halfway again when I returned to the car. Its the 4th time now so will report to dealer. Each time I reset it following the usual routine but it keeps dropping, with no pattern as to when. This is a real security concern.
PaoloPix
Paolo
Audi A4 Avant - Macan 4
Sorry, I didn't see that someone had already opened this thread for my same problem but on the driver's side.
