Electric Charge Ports Won’t Open
Grahamtaylor
Graham
West Yorkshire
Macan 4s
I’ve had my Macan 4s EV for a few weeks and have charged it a couple of times without issue. The car is fitted with electric charging ports. Today I attempted to open the charge ports and neither would open either physically or via the PCM Menu which says. ‘Function not available’ when selecting either the AC or DC port. I left the car for about 6 hours and returned with the same outcome. Has anyone encountered a similar issue?
henrus
Henry
Bay Area
There have been several reports that the electric charge ports are unreliable. You can’t manually open them? You should be able to do that (as long as the car is unlocked)
Grahamtaylor
Graham
West Yorkshire
Macan 4s
Hi, according to my Porsche dealership, there's a mechanism to release the chargng cable if it's stuck (via the boot/trunk) however there's no manual release for the chatging ports. On the Taycan there was a tool top force the door open, this isn't the case with the Macan EV.
henrus
Henry
Bay Area
Ah ok. I mistook the cable release for the door. Does the other side also not open? I think a trip to the dealer might be in store
rcomeau
Roch
Montreal, Canada
2019 Jaguar I-Pace
Make sure you go before you drain the battery too much that you don have the range to get there!
llindenb
Larry
United States
2025 Macan Electric 4S
The electric door is definitely wonky and unreliable in the cold. My sales guy strongly discouraged me from ordering mine with this option (even though I really wanted it). Hopefully it’s just a bunch of software tweaks relating to the sensors, but who knows…
MattU
Matt
Seattle, USA
@Grahamtaylor how did you resolve this? My car is in the same state. Nothing I try will open the charge ports.
Electric Macan EV Electric Charge Ports Won’t Open IMG_2571
Grahamtaylor
Graham
West Yorkshire
Macan 4s
Hi @MattU. Ultimately the dealership fixed it. They were somewhat vague about how they resolved it but claimed it was a software problem which required an update to fix the fault. Luckily I had about an 80% SOC so it wasn’t a big deal to get it to them and back before the car died.
Taycan went through a phase of this in the early days.
I've been fortunate with mine and on 2 cars over 4 years have been reliable so far.
A 12v battery disconnect to force a hard reboot might help.
Hopefully it's a software glitch and not a failed charge port.
Images are for freeing a cable but may form part of releasing the door mechanism.
Electric Macan EV Electric Charge Ports Won’t Open Screenshot_20250310_135808_Chrome Beta
Electric Macan EV Electric Charge Ports Won’t Open Screenshot_20250310_135818_Chrome Beta
MattU
Matt
Seattle, USA
Thanks @Grahamtaylor , @PrudentOcean , @W1NGE. II've got enough charge to get to the dealer. Will followup here with what they say. Hopefully they give me confidence that this won't happen again or that there is a workaround if it does. This issue does not give me confidence in doing an extended trip with the car.
MattU
Matt
Seattle, USA
Porsche dealership here fixed the issue. The explanation was that there was a manufacturing issue and the doors were not seated correctly. Hopefully this is a one-off in my case and doesn't show up on other cars.
Archie
Arto
Finland
Porsche Macan and Volvo EX30
I just bought Macan turbo and after the first week I met a problem with the charge ports - they do not open. I returned the car to the dealer´s service and now waiting for their reaction to this problem. It is not acceptable at all that expensive car like this has this kind on problem.
llindenb
Larry
United States
Yeah, this is a problem. It’s especially an issue in the cold weather and my sales guy specifically told me not to order this option (as many others have said) because of the problems.
I hope they get it fixed for you quickly though.
Grahamtaylor
Graham
West Yorkshire
Macan 4s
It’s happened to me a second time over the last two weeks. I organised for the vehicle to be “recovered” once again through Porsche Assist meaning I was supplied with a temporary car. The fix was the same as last time, Porsche reprogrammed a control unit resolving the fault. Still have no idea what caused this to happen which is a concern.
